Few q's on my build
  • Thread starter Deleted member 12106
  • Start date
D
Guest
I'm working towards building a decent storage server that will also have a few VM's on it for www and file transfers.
I have the following:
RocketRaid 4320
Chenbro CK12803 sas expander
Norco 4220
The cables I am in need of to connect the sas back plane on the case to my card should be Sff-8087 to sff-8087, correct?
Also, PSU requirements, per this calculator, it tells me I need 791w of PSU. I am struggling here. Should I be looking at an 850w unit or should I just go to 1kw? Part of me says go bigger, the other part of me says don't waste the money.
The PSU I am looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139007
CMPSU-1000HX
Mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182211
Super Micro MBD-X8SIL-F-O
Ram: (QTY 2)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820139077&Tpk=KVR1333D3E9S
4GB 240-Pin DDR3
I am not sure what I am going to do on CPU. Part of me says quad i5, the other part says xeon.
How does it look? Thoughts?
Looks good but I highly doubt you will need that PSU. By all means get it and be happy with it for many years to come, but it isn't necessary.
If you have no thoughts of expanding to a dual CPU system int he future I'd probably think about this.
I got one when they first came out and it has been the single most reliable part of any system I have built since. And it certainly has enough juice to power as many drives as you can fit in that case plus a quad core Xenon (which I also recommend you get so you can use ECC RAM).
I gotta say.....I was all for xeon...but I am extremely satisfied with the i5 i got, it works great in the server environment.
So you're saying an 650 is ample then? The unit you are linking is a 650, per the PSU calculator it is giving me an estimate of 723, I think I'd want at least an 850.
From what I gather is this board only uses ecc ram and with a desktop cpu, it does not take advantage of the ecc.
For what I am doing, I think core i5 would be enough, I may buy the CPU last in hopes of prices falling.
For 24 drives and that setup, you'll be fine with any decent quality 750W PSU. However considering that 850W PSUs aren't that much more in costs and for your own peace of mind, minght as well go for a 850W PSU:
$130 - Corsair 850TX 850W PSU
But a 750W PSU will be fine:
$110 - Antec Truepower New TP-750 750W PSU
For the cables, yes you need SFF-807 to SFF-8087 forward breakout cables. Note the forward part. That's the one thing you have to make explicity sure that the cables are. Something like these:
$15 - 3ware SFF-8087 to Multi-lane SATA Forward Break-out Cable
CPU wise, do note that if you get any of the quad i5 CPUs you will have to get a seperate video card as the onboard video display on that motherboard are designed to work with only the onboard GPU of the Clarksdale based Core i3, Core i5 duals, and some of the Xeon 3xxx series.
Useful information, thanks! Looking at those cables, they fan out. The case I bought has a single plug back plane for 4 drives, is that the correct cable?
What the shit, are you serious? Is there a list of CPU's that will not require me to add a separate video card? My biggest thrust for this board was to not have any add-in cards if I did not need them, hince onboard video and dual lan.
The case I am getting is the norco 4220, not the 4020.
4020 backplane:http://www.awfulbooks.com/eBay/Norco-4020/unboxing/fullrez/backplane.jpg
4220 backplane: http://img5.imageshack.us/img5/7605/rpc4220014.jpg
The supermicro board also has Matrox G200eW for video, and I am seeing this on AMD boards, this shouldn't depend on the CPU?
A xeon isn't needed for a home server. A quad i5 will be more than enough. You might want to verify that that board will work with one though, says dual core i3 and pentium. Remember that with those you will need unbuffered ecc, if you want ecc.
I would look at a quad core AMD over a dual core Intel part. More physical cores will be better for VM's than HT. Plus almost all AMD chips support ecc. There are some non-server boards with ecc support too, check out ASUS.
Sorry, I copy-pasted the wrong link:
$15 - Norco C-SFF8087-D SFF-8087 to SFF-8087 Multilane SAS Cable
It shouldn't. You know what? My mistake on that. The Xeon 3400 series CPUs do not come with an integrated video chip yet are on the supported category for that motherboard. Totally missed that. However the Core i5 CPUs are not on that list though. So assuming that the motherboard cannot support Core i5 7xx series CPUs, I recommend picking up the Xeon X3440 for $243 as that's the cheapest quad-core Xeon CPU supported by that motherboard with HT:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117225
Wow, that calculator isn't very accurate. For the system in my sig, it says I need a 580watt PSU. I'm running a 500watt and am currently eating only about 250watts under load. Take it with a grain of salt. ;)
I have used that Corsair with 21 HDDs, 2 ODDs, a 3870 and a Q6600 on a 50% OC for extended periods of time. You are just going to have to trust me. It will be enough. Right now I'm running the same setup without the ODDs OC or video card on some Corsair 400 watt thing. Runs fine.
And PSU calculators don't work in general. Most of these PSUs are designed with things like tri- SLI in mind. SLI 580 GTX consumes a lot more than 20 HDDs do.
The manual for the board doesn't ref any core i3 in it. My guess is the i5 would work but may not be supported. I have a Dell sc440 that is running a core 2 duo e6600 and 6gb of ram, it does not support core 2's or more than 4gb of ram per dell's specs.
http://www.intel.com/support/motherboards/server/s3420gp/sb/CS-030740.htm Intel says the north bridge works with core i3, Pentium, celeron, and xeon.
Some of the reading I have been doing, some are saying there will be price drops at the end of the month for sandy bridge cpu's so I might wait on the CPU until I have everything else together. I still want to find some temp controlled fans to slap in the norco. I don't want any knobs to deal with as I plan to put this guy in between the floor joists in the basement.
I'll prob grab this guy. I may try to find one that is more efficient so I can cut down on the draw/heat. I have enough stuff plugged in right now that I do not heat my basement:(
I was going to gank the PSU from my WHS box but I think I might use that as a backup to this box and power it(whs) down when not doing backups.
I couldn't find enough info on the MBD-XSIL to convince me it was a good idea to gamble on a core-i5.
Sooo...
I have the following on their way:
Norco 4220
8gb unbuffered ecc ram
MBD-XSIL-F-O
Xeon X3450
Corsair 850W PSU CMPSU-850TX
I have enough stuff to get the core of the server together and up and running, the OS will go on a 2.5" disk I have here, and I am also looking at volt modding the fans and getting them on some sort of a tstat, 7v for temps a-b, and 12v for temps c-d. I got some homework to do there.
The OS will be win2k8r2 with hyper-v to start with as I unload some load from my esxi box.
running VM's is another strong reason to go the Xeon CPU route and take advantage of ECC memory. i wouldn't dream of anything else.
8gb ddr3 eec 1333
supermicro X8SIL-F-O, lga 1156,
Xeon x3440 (quad core/turbo/hyper threaded sex)
Chenbro CK12803 SAS expander
RocketRaid 4320 raid controller
250gb WD Black 2.5" for OS
Norco RPC-4220
Corsair TX850W
No storage drives....yet
A floppy cable, what the fuck?
Beefy manual..
Board, ram, CPU installed, raid controller, sas expander
LGA 775 cooler on left(pentium d, early c2d), 1156 on right. Wow
they are getting small!
Say no to default thermal paste...
The tools of choice for heatsink paste and application:)
The key to the sucess is a thin layer that does not squeeze out:)
In the case, no fans hooked up:(
Drive laying loose, for now.
Man cave:)
On board IPMI is neat.
I thought I would share. I am looking forward to retiring my 2 current servers to replace them with this. Tentitive plan is 2x10 disk raid 5 arrays and use my current WHS for backups, and power it down.
Game plan is:
Win2k8 R2 DC Edition
Hyper-V
1 win2k8r2 STD VM for DC and SCVMM
1 win2k8r2 STD VM for misc shens
1 win2k3r2 ent box for www/ftp needs
The Dell SC440 with the e6600/6gbram will be retired after about 4 years of 24/7 use.
One of the things that was frustrating was trying to learn more about IPMI and what it can/can't do and what it looks like, here are some more pics of it.
Also, you DO need to upgrade to the latest firmware, the stock/orig firmware sucks, the new one is more stable, stays connected, and added a few other options.
More IPMI pics...
Rebooted, here is the first splash screen..
Windows booting..
Windows finalizing role updates.
Done and ready to log in.
I really like this. Not sure if dell rolls something like this, but this is much like using a vpshere console window to interact with a VM.
More IPMI pics...
Windows booting..
for a second there i thought you were going to run esxi :)
Na, I got a box that does that. I don't think I am going o get to it this week, but I need to get in to the esxi box and swap some drives. Some way, some how, I want to get my raid array from there and into the norco in addition to the 20 bays in the front:eek:. I think I got some old HD racks, I can never leave well enough alone:(
I am going to be getting this board to upgrade my ESXi server.
Should the Perc6 work ok with it?
Also can you explain how the IPMI stuff works? how do you install an OS. Is there a way to mount an ISO over the network?
