WabeWalker
- Sep 3, 2007
Fermi's lead tends to be LESS than 15%. In games like Crysis Fermi has almost no lead at all. BC2, a demanding DX11 game, Fermi's lead is less than 10%. Indeed, the only really demanding game where Fermi currently has a lead greater than 15% is Metro 2033.
Just Cause 2 is as demanding as Bad Company 2 - so why did you fail to mention that the GTX 480 beats the 5870 here by a whopping 25 frames per second?
And what makes you believe that the Metro numbers won't continue for other DX 11 games in the future?
The ATI cards have been out for six months now. ATI has had time to work through driver issues based on real-life gaming results - Nvidia hasn't. And yet right out of the gate the GTX 480 is running Metro a lot better in DX 11 than the 5870.
The GTX 480, at the so-called 'lower resolutions' is clearly wiping the floor with the 5870.
And I love the way you guys mix and match your arguments. In one breathe you say that we need to benchmark using modern, cutting edge games... but then you throw in Crysis, a three year old game, because you see that the GTX 480 is only beating the 5870 by 6 frames per second.
You're cherry picking the results, man. You're seeing what you want to see.
A trend has been established in the past ten years that everyone here should be aware of by now: A card manufacturer produces a new generation of card, and then between six and eight months later, they release another card with two of those GPUs on it.
Then, between six and twelve months after this, they release a new generation of card again. This new generation of card usually runs as fast as the dual GPU card of the previous generation.
The card that people need to be focusing on here for comparison is the GTX 295, because that was the dual GPU card of the previous generation for Nvidia. Anybody expecting significantly better results than that obviously had ridiculously high expectations.
The GTX 480 is posting numbers that are virtually identical to the GTX 295, and in some cases are besting them - exactly the same thing we've seen before.
