_PixelNinja
- Feb 12, 2011
Many people have complained about Steam installing the DirectX redistributables every time we install a game. We know these files take up unnecessary space on our drives and there is not much we can do about Steam installing the whole package each time. However, what we can do is find the unnecessary files and remove them safely with this tool I found called Steam Cleaner:
I have tried the application myself and it removed 3GB of files. I have friends who have had up to 6GB freed on their drives.
You'll find Steam Cleaner here. This is a free OpenSource application made by a French programmer called Jonathan Lermitage.
The good old time:
When you installed a video game from a CD or a DVD, you installed some redistributable packages too : DirectX, Games For Windows Live Redist, VC Redist, Rapture3D, NVidia PhysX Redist, etc. They were installed from the CD/DVD, and those installers didn't stay on your hard drive.
Now, Steam, the problem:
The Steam application allows you to download games from the Internet and install them, but what about these redistributable packages ? You probably saw they are installed the first time you launch your game, OK, but what happens to these files when they go wasted ? The answer is very simple : Steam doesn't delete them. An example : install the first complete season of Sam & Max (6 episodes) : every episode is about ~300MB. For each of them, you can count 100MB for the DirectX redistributable package. Yes, it is about a third of the game files size, and they are not removed by Steam. For 6 episodes, you could save 600MB. Imagine what you could save for 10 or 20 games.
The solution:
A little tool that is able to list every redistributable package stored on your Steam directories, and allows you to remove them. This is the goal of TikiOne-Steam-Cleaner. This is a very simple program : set the Steam SteamApps folder (this is a sub-folder of the Steam application), click "Search", you choose what file or folder you want to remove.
