That's a good looking rez, to bad it costs as much as my D4 pump. It would be great if they made those new style rez in a dual 5 1/4 format as my water cooling system is external and I have room for a tripple 5 1/4 bay rez.sdk said:
That one looks like, anyone have any opinions on this one too?flat4 said:
That's too restrictive for a decent 1/2" system.R1ckCa1n said:
bellevegasj said:
MikeP said:So thats a no res, no T line, no nothing setup basicly. Just a verticle tube thats got a removable cap (fillport) on the end. It actually makes sense.
thewhiteguy said:That's too restrictive for a decent 1/2" system.
Bio-Hazard said:Notice that he said
"as the
flow rates with the pump being used aren't high enough to convincingly justify
the use of 1/2" barbs."
Which sounds like to me, that if you had a higher flow pump, then the use of 1/2 inch barbs and tubing be a big help.
I also read Pro Cooling about everyday and most if not all recomend 1/2 tubing if at all possible.
dagamore said:you do see that the "just a verticle tube thats got a cap" is connected to a T fitting, and is what most people would call a t line, and with its placement, it would fill the sysetm fine, would a res fill/bleed faster sure, but it does have a t line.
R1ckCa1n said:Not exactly..... everyone here seems to be under the impression using 3/8" will hurt, when in fact when done correctly can be just as effective. There are plenty of 1/2" systems that perform WORSE than a 3/8" system. I personally have gone through at least seven 1/2" configurations and find 3/8" much more pleasant on the eyes and easier to use, all while not sacraficing performance.
1/2" is more of a myth than required. / looks like a good case for Mythbusters!![]()
Paying $70 for a res, plus $10 for mounting kit, plus $10 for spray thingy seems a bit silly... but hey, what do I know?
Where did you find an acrylic tube? I need something like that and I'm in the US too so maybe a link or a store?whoami? said:I've got a custom built res in my case right now (12" long 2" diameter acrylic tube),
CrimandEvil said:Where did you find an acrylic tube? I need something like that and I'm in the US too so maybe a link or a store?![]()
fallguy said:My two favs are the Innovatek Tank-O-Matic, and Aqua-Computer's Aqua Res. The Tank-O-Matic is very easy to fill/empty when placed outside the PC.
