- Aug 7, 2004
I gave up on the game and went to play more Valhalla with my subscription. Seems the general thing for Ubisoft games to just wait a year to actually play it.
I'm enjoying the game but it's definitely too easy, can literally just run into bases and one tap everyone without much effort.
What kind of gear you all sticking with? I can't bring myself to take off the parkour stuff and it was the first complete set I got.
Do you think Steve had the HD textures working in his review?crazycrave sucks even amd gpu not loading textures,ubi got some splaing to do
I can say he did the correct way of testing the Far Cry 6 game.He restarted the game after every change in settings. I can not say if he had problems or not with HD textures.From the footage shown at the end of the video, it looks like it was good,if i was to guess I do not think the footage was with HD textures. anyway the video I showed was with HD textures off.Do you think Steve had the HD textures working in his review?
isnt turning off all your other background crap part of troubleshooting 101? AB/RT have caused me issues before and is the first thing i turn of if crashing. basically anything else touching the nic, sound or vid can potentially screw with a game.Ubisoft is blaming 3rd party programs for your performance and crashing woes. Like to stream and/or chat while playing their games? How about something as simple as monitoring your hardware?
https://www.ubisoft.com/en-us/help/...bling-background-applications-on-pc/000063761
Credit where it's due, the article does explain this as a critical troubleshooting step. RGB software is particularly notorious for causing all kinds of issues. Streaming can also rob hardware resources that certainly do affect a game's performance if streaming from the same PC you're playing on.
Is there a fix yet for the Nvidia textures? Seems like there has only been one small patch so far. Holding off on this for a bit because it seems like it needs some patches for the PC version.
No. Who knows if it will ever be properly fixed. Still not a single patch for this game, and it's been a couple weeks.Is there a fix yet for the Nvidia textures? Seems like there has only been one small patch so far. Holding off on this for a bit because it seems like it needs some patches for the PC version.
Hey guys. Someone here said that graphic is outdated. Yes?
Not very good graphics. Ok graphics only.Hey guys. Someone here said that graphic is outdated. Yes?
Alright,thx.Not very good graphics. Ok graphics only.
The 16GB requirement doesn't even make any sense given that the 'official' requirement is 11GB. However, the fact that this is happening on 3090's even tells me it's an issue with how the game is allocating/streaming the textures. It has nothing to do with hitting a usage wall.They certainly didn't fix the HD textures issue.
Why is it that when you enable HD textures, it shows a bump of like maybe 1 GB of VRAM usage in the menu, but in game I constantly get a "low VRAM" warning at the upper-right and the textures look like shit? What a poorly-coded system.
Also, if you truly need 16 GB of VRAM or whatever as well, that's also a pretty huge fail. I know it's an AMD title but it seems purposefully gimped on other cards.
I'm not even playing at 4K either, this is just 1440p.
Yeah, I can only speak to what the game is telling me, which is that it should only be using roughly 6 GB of VRAM at my chosen settings, but I get a constant "Low VRAM" notice in the corner with HD textures enabled.The 16GB requirement doesn't even make any sense given that the 'official' requirement is 11GB. However, the fact that this is happening on 3090's even tells me it's an issue with how the game is allocating/streaming the textures. It has nothing to do with hitting a usage wall.
On my 3080ti w/ max settings and the HD textures I don't get any VRAM warning. However, i'm obviously getting the bug.Yeah, I can only speak to what the game is telling me, which is that it should only be using roughly 6 GB of VRAM at my chosen settings, but I get a constant "Low VRAM" notice in the corner with HD textures enabled.
I agree it seems like a bug or some issue they need to work out.
PC, Luna, and Stadia:I saw what appeared to be a very small update for the game. I'm not sure if it's anything at all. I don't see notes anywhere.
I get the complaint, I guess, but I find it amusing if anything. I think the "outrage" over this is overblown.Far Cry 6 is sending emails mocking people for quitting the game
https://twitter.com/BrendanSinclair/status/1452986713098407945
That's totally fair, I didn't think about that.The emails are irritating because a lot of people simply aren't playing because it has numerous issues and they have yet to release a decent patch since launch.
