carnageX
- May 25, 2009
For me it's:
Weather - F°
Computers/Electronics - C°
+1 to this.
For me it's:
Weather - F°
Obviously the Yen is more precise since there are 120 Yens for every Dollar ... going by their arguments![]()
Funny, I heard it was Brian Williams.Never. Al Gore created the internet and Fahrenheit. True story.
It was so stupid to pick water as the measurement to base everything as rightfulness. 0 is ice, 100 is boiling? So stupid.
Not that Fahrenheit is much better, but at least it's closer to what humans experience.
http://en.wikipedia.org/wiki/Fahrenheit
Its ignorance of the idea variant of F existed long before specific points on the scale were pegged to Freezing and Boiling points of water which were fractional adjustment.Not sure if this is sarcasm...
Fahrenheit is an anthropomorphic scale. 0° is around the temperature when it's unreasonably cold and 100° is when it's so hot the only thing you can do is sit in a body of water. In the shade, Holding a box fan. Drinking cold beer. And let's not forget to mention, hating your miserable excuse of a life and hoping that you drop the fan in said body of water to put you out of your misery.
For all things that aren't anthropomorphic, SI is obviously the way to go.
The attitude is your not metric what is wrong with you retard.
I keep waiting for the Euros to come up with a decimal time system, and tell us how stupid americans are for not adopting their superior and awesome 100 second minutes, etc.
Fahrenheit wins because:
Fahrenheit 451 has a much better ring to it than Celcius 232.777778
Just doesn't have the same sound.![]()
Let's play spot the stupid countries....
I call BS. You want accuracy you go Kelvin, and if you're gonna go Kelvin then Celcius naturally extends from there as the ideal unit for everyday use.
Actually, seconds are an SI unit.
But I thought the SI System is base 10 how can time be when it is a base 60. When should change time to base 10 to make the math easier.
0°C - water freezes. 100°C - water boils.
Humans are mostly water, at ~28°C.
Celcius allows you to precisely gauge whether your environment is pushing your body towards vaporization or solidification. Easy to read between the lines?
to those saying "why wouldn't you go to decimals" guess what the precision is with decimals... hint it's still a factor of 1.8
Now maybe you don't care about that level of precision, in which case fine, but stop pretending the accuracy differences change just because you go to decimals, because it doesn't.
For me it's:
Weather - F°
