Wierdo
- Jul 2, 2011
edit: reduces chances of mistakes
Did you read my two posts? No? then do so and come back with a reply that isn't stupid.
You're wrong, Celsius ties in directly with the rest of the metric system, that's the entire beauty of it.Your argument about having to memorize 32F vs 0C applies to your 37C too. It's easier to know that its getting pretty hot the closer you approach 100F.
In the end F and C really don't make much of a difference. It's a matter of what you are used to. Unlike the rest of the metric system, there is no easy math benefit to it. 1000 meters = 1 kilometer. That's easy. But there is no need to do that kind of conversion with temperature. No one calls 3000F (1648.8C) 1.6 KC.
C is just an easier way to remember the freezing and boiling points of water. That said, water technically boils at 99.97C at sea level and 71C at 29,000 feet.
Considering you seemed to answer your own question within your posts, I thought I should make it a bit more obvious. Those who work in scientific or engineering fields are going to have a much stronger preference towards the metric system because they use it daily and it is much more efficient. Not sure why you always find the need to attack others if they don't agree with you.
That's how it works in engineering, you look for efficiency gains and reduce margins of error. It saves time and resources, and reduces mistakes such as the above from happening. Using something because of tradition is ok for non-scientific matters, but when real work needs done then you use the best tools for the job, and for science/industrial applications it's a no brainer for a respectable establishment in a competitive environment.
My argument is it's probably not a big deal except when the task at hand is complex and important. We might as well teach our kids proper science in case they end up having to compete with others on the world stage in the future imho.
For me it's:
Weather - F°
Computers/Electronics - C°
I don't disagree but it depends what engineering and where. For example, civil engineering and manufacturing engineering in the US use the imperial system because it is easier due to tools, equipment, diagrams, measurements, etc... being in imperial units. Using metric for these two engineering disciplines would be inefficient unless everything was completely changed over.
On another note, aerospace engineering also has some fields where it also a mess since the most common units the world uses in aviation are feet, knots and nautical miles.
In my job as an engineer, I prefer metric but I know quite a few engineers in the above mentioned who prefer imperial.
I'm sorry, but a positive number like 5F should NOT feel that cold...
Metric FTW!
How much does a cubic centimeter of water weigh? One gram. What volume is that? Its one milliliter. How much energy is needed to heat that mililiter of water by 1 degree celsius? Exactly one calorie. Now do this calculation in english/imperial.![]()
So the caveat on that is no decimal places *facepalm*Fahrenheit gives you almost double1.8xthe precision* of Celsius without having to delve into decimals,
no. There is a US gallon and an Imperial GallonBtw, when is England converting to 3.7L gallons instead of 5.0L gallons ? Doesn't the rest of the world agree with us that 3.78L = 1 gallon?
So you don't think you can make an accurate guess based on sea level boiling point? Or make a reasonable guess for other fluids using what you know about water as a baseline?What is the boiling point of water at any elevation other than sea level? hmmm, hard to say. Maybe there's a formula somewhere.
But again, Celsius ties into an entire SYSTEM, which Fahrenheit does not, and there's no good reason to have redundant systems when the only real advantage of Fahrenheit is that people are familiar with it, when they would be quickly equally familiar with Celsius once converted, along with using a standard the same as the entire rest of the world and that works better with the rest of the metric system that also needs to be adopted ASAP.But it's not stupid to say that Americans still use Fahrenheit, and that we do because of the reasons listed in the article (also tradition and stubbornness). 0°F is very cold, possibly dangerous if you are under dressed and there's a hard wind. 100°F is very hot, and possibly dangerous if it's very humid and you are working hard. I've been in 115° weather in a Las Vegas summer. I've been in -20° weather in an Idaho winter. These are expressions of my human experience, not scientific records. Fahrenheit is fine for this.
You are making my point for me. Accurate guess? Well if we don't care about real accuracy, then let's use whatever system we like.
And again, nobody gives a crap about being one percent closer to boiling water when the decision you are making is whether or not to wear two coats and ski goggles or shorts and sandals.
"How hot is it outside today?"
"It's 16°C outside, which is 16% to boiling if the air were all water. Just thought you'd like to know even though that knowledge is currently meaningless since the way humans perceive temperature in air and water differs immensely since water has a much higher specific heat. Did you know that if one milliliter of that air were water that it would take . . ."
"Yeah I just want to know if I need a jacket or not."
For every day things it doesn't matter what you use, F or C. I don't care. C being a part of a system doesn't matter for every day needs. For every day needs of boiling water it doesn't matter either. Since boiling water is a constant temperature, nobody cares that it's 100°C or 212°F. Boiling is boiling. For every day purposes you'll know that if you live at a high altitude you'll need to boil things longer, regardless of whether you prefer F or C.
Again, we're not talking about what is better for science. Celsius is obviously better for science. But for every day needs there is nothing wrong with Fahrenheit, and as the article suggests, there are reasons why it might be better.
This isn't rocket science. One provides you a common universally understood baseline to make accurate predictions from, the other does not.You are making my point for me. Accurate guess? Well if we don't care about real accuracy, then let's use whatever system we like.
OF COURSE WE ARE!Again, we're not talking about what is better for science. Celsius is obviously better for science. But for every day needs there is nothing wrong with Fahrenheit, and as the article suggests, there are reasons why it might be better.
I'm pretty sure we are the only country to lose a $700 Million space probe because someone programmed imperial units and not the SI units that were expected.
WTF thinks like that when they use SI/metric units *FACEPALM* (im running out)
"its 61F"
"oh quite warm thanks"
If you HAVE to do calculations, the metric system is infinitely easier to work with . . .
Why do you need to use two different units of measure, when you can just use one? The one that the rest of the world is using?
What ADVANTAGE is there to using BOTH Celsius and Fahrenheit, because we sure as hell can't afford to never use Celsius in our lives, but we sure as hell can get rid of Fahrenheit and the whole rest of the arbitrary imperial system.
There is no problem with using Kelvin and Celsius as I already pointed out, because they are literally the same metric just using a different baseline for zero. So when you know and use Celsius, you already know and can use Kelvin when desired. Both tie into the other measurement systems and are in global adoption.We use different units for different purposes. Kelvin is technically the SI unit, not Celsius. Celsius is nice, however, because its freezing and boiling temperatures are 0° and 100° respectively, and since it is derived from Kelvin the two are easily converted.
But Fahrenheit is also nice for every day use. So if I'm measuring the background radiation of the universe I'll stick with Kelvin and then since I live in the US I'll go home and tell my wife that it's 61°out and that she may want a light jacket when we go on a run. My advantage is that I relate to 61°F more than I do 289.26°K and I don't sound like pedantic jerk to my wife and friends.
except your response was latching onto a very powerful aspect of SI/metric which 99.999999% of people either don't know of or care about and use it to dismiss SI.My reply to Ducman69 is in reference to his argument that Celsius is better because it's integrated across all units (mole, liter, meter, gram). My response is that nobody cares when all you want to know is whether or not you need a jacket. See how I fixed the quote you fixed to use Fahrenheit? See how it makes no difference that there isn't a relationship from temperature to volume in Imperial units? This is no different than how people who use metric don't care about the relationship of degrees Celsius to volume. Again, my point is made for me. Ducman69 says metric is better because of that relationship. I say that for everyday tasks it doesn't matter and make a hyperbolic example of it. You reiterate my point. I am still right.
sissy, 10C is t-shirt weatherAlso, 61°F / 16°C isn't quite warm. Most would say it's jacket weather.
Map is wrong. England uses degrees C, but mph. My co-worker there and I talk constantly and that is what is in common use. AFAIK mph isn't metric.
My British Physics text in the late 1980's or early 1990's said that it would have cost billions of dollars, to replace the road signs, to convert from miles to metres ( kilometres ). It was cost prohibitive.
I imagine that the States being such a large land mass, would have logistics problems too? You might end up with some portion of an American city with imperial and the rest of the city in metric? I wonder how other countries managed those kinds of transitions?
A nonsensical argument, considering literally the entire rest of the world managed it just fine.My British Physics text in the late 1980's or early 1990's said that it would have cost billions of dollars, to replace the road signs, to convert from miles to metres ( kilometres ). It was cost prohibitive.
I think you mean 10 stones 2 pebbles, right? And if you throw a woman in water and she floats, then she's a witch.The general public in the UK still uses stone for weight:
http://en.wikipedia.org/wiki/Stone_(unit)
My weight in 65 Kilograms is 10.2 Stones.
