as an add-on to this post, id like to know what kind of angles people are using with their eyefinity setups. as well as how close you sit to the main screen ( are the side screens actually in your peripheral vision or not really) im having a bit of a time trying to find a happy middleground. i play fps and driving games. seems very weird if i sit back too far. for the few fps games ive played so far the angle i have mine on seems odd. could be i just need to get used to them. im not over my nausea yet. seems everytime i take a larger step up in screen size it takes a while to get used to it, and one of the side affects is feeling nausea.....am i the only one? so let me know what your angles are please, and what u play with them at those angles.
I tried my U2410s in portrait and thought they were WAY too high up to work. Maybe I sit too low in my desk....
I did try portrait and it was horrible for me, in FEAR it felt like all the displays blended together and the main monitor felt twice as small as it really was and bezel frames clearly there ingame.
landscape is much better, still as I said before I only see 35% of side monitors...
I don't have an Eyefinity setup but wouldn't landscape make the most sense?
I only ever played games using Eyefinity in landscape orientation. I loved it. I found the extra peripheral vision in Call of Duty 4 to be VERY useful. It even saved my ass a couple times. That said I'd like to see it in portrait mode with 3 30"s.
trying to save up and locate my 3rd Dan
Man I need to get some more monitors. Though my Ikea Jerker wasn't up to the task of holding three U2410's or Dell 3007WFP's which is what I'd want to go with. I've already got the one Dell 3007WFP, and I'm debating whether or not to buy 2 more 30" Dell panels or switch to 3 U2410's. I think I'd be happy with either, but I kind of thing that 3 30's are the way to go. But damn that's an expensive route to go with even when refurbished panels show up on Dell's site.
BTW, I just picked up an Ikea Galant with most of the options so I'll have the space for either choice.
yang88she said:trying to save up and locate my 3rd Dan
I can't see the value in Eyefinity 3x1 portrait mode. Seems a 30" panel would be better; similar aspect ratio, no bezels, lots of pixels. The whole reason I went with Eyefinity is because the increased FOV in landscape mode makes the game experience so much better.
The bezels don't bother me because I rarely actually look AT the flanking panels, yet I'm still very much aware that they're there and they definitely enhance the experience. I've got to believe the bezels would be pretty annoying in portrait mode. Am I wrong?
Here is a good example. I tried to take this picture from the exact same spot in the game. It is from 3 different setups I could do with Eyefinity. 3 - 24" in Landscape...3 - 24" in Portrait...1-24" + 1-27" + 1-24" in Landscape, and this is the setup I have stuck with the longest so far.
3 - 24" in Landscape = this felt too narrow and skinny
3 - 24" in Portrait = The highest and best immersion factor
1-24" + 1-27" + 1-24" in Landscape = This gave the best wide viewing angle, but center display is nice and tall and not too narrow/skinny like if all three were 24"
The best combination I have used is a PLP, matching vertical res, left and right monitors are great for desktop work and gaming is perfect for usable fov without interruption.I still have hopes for eyefinity support.
I'd love to grab some 20" panels for this but I won't get my hopes up for support anytime soon. Truth be told I'd rather have 3 30" panels, but such an option would be more palatable in the cost department.
I've been looking at the 28inch 1920x1200 hanns g monitors. $900 for 3 of them isn't so bad at all.
But what kind of panels do they use? I'm spoiled by S-IPS panels like my Dell 3007WFP.
TFT . I used one for awhile they look really good to me. I use a S-IPS in my office the same one as you I believe. The panels are a step down , however eyeinfinty on them is a step up .
I don't personaly own the setup but i built it for my buddy. 3 of them for gaming is godly.
To be honest though 3 30's is a bit much. The desk space alone is huge. If you utilize a standard desk it will take all space from front to back and likely set the center monitor too far away for general use. Wouldn't mind trying 4 2407's, may be next on the list.
I bought a new Ikea Galant to accommodate and Eyefinity setup. 3 30" panels won't be a problem on that front.
which galant desk? as I'm in need of more room and the ikea website comes up w/ several different options
