do you guys think gaming on one big screen is better than 3 smaller screens?
whichever is larger.
long time lurker, first time poster.
I plan on getting a Dell 30" here in the next couple of days and have two mixed brand 21" monitors. The resolutions will be the right size but the monitors won't line up perfectly and for now that will be ok. I plan on doing portrait-landscape-portrait. My question is I know eyefinity doesn't work for this resolution without some other little fixes and software and I'm ok with that, I don't want tri-screen gaming (just want web browser in one, vent in the other, temp monitoring, etc) but will my one card (6970) push all three monitors in different resolutions like that? I'm 90% sure the answer is yes but I just wanted to be 100% sure.
finally decided on the U2311 x 3 and Dell epp gave me the best deal ever....$239 a piece shipped.
I think these should work for minidp to dual link dvi (for your 2560x1600 lcd's)
http://www.amazon.com/Accell-B087B-003J-UltraAV-miniDisplayPort-Dual-Link/dp/B0030XMREG/ref=sr_1_1?s=electronics&ie=UTF8&qid=1304280159&sr=1-1
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10428&cs_id=1042802&p_id=6904&seq=1&format=3#specification
for up to 1920x1200 , these work, just fyi....
http://www.amazon.com/Accell-B087B-006B-DisplayPort-Single-Link-Certified/dp/B004071ZXA/ref=sr_1_1?ie=UTF8&qid=1294684656&sr=8-1
http://img.photobucket.com/albums/v141/raoke/IMG_3581.jpg
Thank guys, I just wanna make sure before I get the 2nd mini DisplayPort to dual link DVI adapter.
@Dan_D: Yeh I know, I just built a new rig 2 days ago with 2600K and HD6970 CF since I believe the 2GB RAM will come in handy at 7680x1600. Just didn't realize that unlike the GTX 580, the 6970 only has one dual link DVI so I would need 2 adapters to set up such thing.
The 6970 isn't powerful enough to handle many newer games at that resolution despite having the RAM for it.
There isn't a solution to max out all games at that resolution, at least in my case when I can only use 2 cards so I think my best bet would be HD6970 CF for now then wait for the next gen cards. Heck I can even get a 6990 when the price drops to do Tri Fi and I believe it will give me the best bang for the buck. I just wanna try out Eyefinity and play some games at decent settings, rather than that I'll just stick with gaming on a single 30" when I wanna max out everything.
Is the crt somehow displaying 1920x1080? Cause otherwise, that ain't eyefinity.
Very nice arms. Clears up so much desk space when you get rid of the monitor stands.
Can anyone take some basic measurements of their tri setup?
Since the monitors are angled in a little, I am curious as to how much space each setup is taking in terms of both overall width and when people don't use a single stand, how much space is required just to hold all 3 monitor stands?
Thanks,
A lot in my case. I need almost the full Ikea Galant desk with most of the options to hold just the monitors, keyboard and mouse.
