PHRESHKHID
- Feb 3, 2011
My contribution to the thread!
I hate you.......
What monitors are you using, if you don't me asking?
My contribution to the thread!![]()
Where's number 5?
Its actually 3x 2311H Dell monitors...
Can't add a 5th one anyway as the graphic card (HD 6950) can only handle 4!
Originally had the monitors in landscape mode with just Dell monitors and it really was too wide for me. Not only that, it took up the whole desk! I prefer portrait, its more like playing in front of a 44inch TV lol
I prefer portrait mode too, its amazing. I get really nasty vertical line tearing that travels horizontally along the screen when playing games/videos in eyefinity in portrait. Does this happen to you? Its fine if I set them up in landscape which is my temporary solution.
Thanks!
Does it only happen on one screen or are you saying it happens across all three screens? Seems that a lot of people report it happens most on the screen that's connected to the odd port (1 on DVI if the other two are DP, or vice versa)... But there's no way around that on the 6950, short of having three DP displays and a hub.
**Figured this would be the best place to post this. Sorry for length, and appreciate any help! I will also be researching on my own as well.**
multiple cheap 1280x1024 (or 1024x768) projectors for 3840x1024 (done with TH2Go) or at side-ways 3072x1280 (exact 24:10 ratio of anamorphic wide-screen cinema/Panavision/CinemaScope)
On a lot of monitors you can just take the plastic case off and remount it on the same stand.. it leaves a much thinner metal bezel. You just need to work out what to do with the buttons etc.
Samsung MD230 is the only prefabbed thin-bezel LCD at monitor size. There are a few big "presentation" screens with thin bezels.
Why don't you get 1920x1200 16:10 displays? That solves the 1080 pixel width issue for you.
Anyone have a triple monitor suggestion for a budget of around 750-800? Just want 3 nice fast monitors for gaming and not that much else
I'm hearing bad things about the viewing angles of TN panels when in portrait mode. I know they're bad, but are they bad enough to prevent a three-screen Eyefinity setup in portrait? I'm currently using one of these and am considering picking up two more when the tax return comes in. How crap will it look?
