I do a lot of work with game (as in videogame) promos. I capture most of the video using this: http://www.amazon.com/Hauppauge-1212-Definition-Personal-Recorder/dp/B0018LX0DY
Currently for my workflow I have an Intel X25 SSD for my OS install where I have all my video editing software installed. Then I just have a separate internal hard drive that I capture the video on and edit it from.
I do get some frame drops and whatnot when recording, so I'm looking to upgrade and set up a raid array for my capture and to edit from.
I'd like to be able to hold a lot of footage so I'm thinking Raid-5 with 2tb drives. I'm looking for a good Raid-5 enclosure that can hold three to five drives at least and give me decent recording ability without dropping frames, and will be fast to edit from.
Also, I'm still a bit confused on how this all works. Do I need the enclosure and then also a Raid card, and does the Raid card go in the computer? My motherboard has an eSata port on it, but is that only for software raid?
