I'm planning on finally getting my storage setup going across the next few months. It'll be 4-5 2tb drives and I'd like to have em in Raid 0, but since I've never dabbled with anything but onboard (and this new setup won't allow for that), I figured I'd ask the pros. Also, this is ONLY for storage. OS and apps will be on a separate drive.
First off, external or internal? I'm not really opposed to either, but I'm curious as to what you guys would suggest. If I go external, I'll be grabbing either either the Lian Li EX-503 (5 drives), EX-50 (5 drives), or EX-40N (4 drives). My choice in external solution is mainly aesthetics, but they all seem to provide what I want. I'm also leaning more toward the 50/503 because it'll mainly be connected to my rig and the network capability isn't too important. If I go internal, I have no idea what card I would go for. Prices seem to be all over the place and as the price goes up, I'm not really seeing a reason. And if I go internal, is there any real benefit to pci-e over pci cards? I'm not too worried about speed since this is going to be storage only.
Second, I don't plan on picking up all the drives at once. I'd like to be able to just grab one or two and add the other three or four later on. I've read that the Lian Li cases were hot swappable, does that mean I can just add as I go without rebuilding the array? If I go internal, what kind of card should I be looking for in order to just add em in? I've read about using cheaper cards and Acronis, but does it create a 1:1 image of what I'm backing up before I add in another drive? Any guidance through this is much appreciated
