My HTPC has two GTX460s in it (not in SLI) in a Biostar P67 motherboard. The CPU is stock clocked. The GPUs behave the same whether they are overclocked or not.
One GPU is connected to the TV via DVI. The other GPU just runs folding at home.
Just like the title says, I leave the PC alone for days or hours and it folds happily. I know it's working because I can monitor its folding at home progress from another PC.
But, as soon as I turn the TV on, the PC locks up.
If I move the mouse before I turn the TV on, I will see a frozen desktop.
If I don't move the mouse first, when I turn the TV on it just says searching for signal.
Then, oddly, pressing the reset button makes the PC shut off (?). Turn it back on again, and I can do whatever I want with it with 100% stability, until I turn it off, leave it for a while, then try to turn the TV on again sometime down the road.
Any ideas?
Any ideas?
