expert or ultra-d
magnum
im getting a dfi board to oc my opteron 165, and im wondering on whether i should get the ultra-d or expert? im not going to sli, as im using a x1900xt, but the expert seems like an overall better board. the power regulation seems bettter as its 4 phase vs 3 phase, and the board layout itself is better. what my basic question is will the expert be more apt at getting the highest stable oc on my opteron, as i figure the 4 phase power is more capable of handling the high wattage dualie.
if you get a good ultra d board you probubly wont see much difference in the o/clock.the price difference is quite large.if you get the latest revision ultra d
revision aa0 i think with the latest bios you would be fine.if 70 dollars is alot to you then the ultra d is probubly gonna do the job for you.if 70 dollars isnt that big a deal to you then go for the expert.the ultra d is a more mature board bios and hardware wise and there is alot of info out on the ultra d,so think about it and go for which ever seems rite for you.....good luck..............................
I have an ultra-D and thought about trading it in for an expert, but decided it wasn't worth the trouble or the $70.
I agree about getting an expert if you dont mind spending the extra money, but the ultra-d is is still an awesome board. Both will OC the hell out of you're chip (if you get a good core :D ), but the expert is "supposed" to be the better overclocker due to things like better power regulation like u said. But like lot of people i couldn't justify getting the expert and spending the extra cash so i ended up with a refurb ultra-d, best choice i ever made :)
I just got the Expert the NB is in a horrible Location IMO.
However when I got i it was $5 less than the ultra-d...go figure...still $200 is alot for a motherboard!
Since you dont have a board now... if you have the cash, get the expert. I will be swapping my board for one soon as I get the money.
The two boards should provide very similar overclocks. So unless you need the additional PCI slot or more than 4 SATA headers, i would go with the Ultra-d.
