byusinger84
- Feb 1, 2008
Has anyone used one of these kits yet? Curious if I should pull the trigger for my 3090. I am having a hard time finding reviews/benchmarks of anyone before/after.
Dude, what are those 2 things on the bottom of your case?I did but my card ended up dying during the process, not sure what I did but the card didn't function when I was done, it also didn't function when I put the stock cooler back on.
It did look good though,
It won't really do much compared to the FTW3 cooler. Slightly quieter and a smaller profile.Finding info has been hard. I ordered it any way so we'll see. At worse the temps should be better.
I'm wondering why he has a 97 code displayed, should be AO typically.Dude, what are those 2 things on the bottom of your case?
I was making a joke about the mechanical drives ;PI'm wondering why he has a 97 code displayed, should be AO typically.
PC wouldn't complete POST with the card installed since it was dead, it would stop at 97.I'm wondering why he has a 97 code displayed, should be AO typically.
Maybe the cooler didn't cool some important parts one way or another and died from heat?I did but my card ended up dying during the process, not sure what I did but the card didn't function when I was done, it also didn't function when I put the stock cooler back on.
I doubt your oc will increase much, but it will be quieter.If I get this hybrid for my 3090 FT3 Ultra, can I expect to be able to OC the card with a higher potential than factory and would this net me a few more fps in demanding games at high res?
Maybe, but there was no signal at all when I powered it up.Maybe the cooler didn't cool some important parts one way or another and died from heat?
You'll still be limited by the power limit, so not really. Keeping the card cooler will allow the card to hit a higher Boost clock more consistently, though.If I get this hybrid for my 3090 FT3 Ultra, can I expect to be able to OC the card with a higher potential than factory and would this net me a few more fps in demanding games at high res?
My experience with them in the past has been good. No issues whatsoever. Most of the failures probably come from user error when installing it. Like I said above, you just need a lot of patience.Is it easy to install this Hybrid. Just watched a video on youtube, it doesn't look too complicated.
And did peoples card die because of lack of cooling on critical parts, or is this hybrid good all over?
