Elden Ring (From Software RPG)
I take it you're using a heavy weapon, possibly a colossal one? If you want to swing faster and/or consume less stamina you need to switch to a lighter weapon.
Have you been upgrading your weapon and shield? +25 is the highest you can go. The Greatsword has over 400 base damage at +25 compared to 164 at +0, for example, with STR scaling improving to a 'B' from a 'C'.
So here's my weapon:
I don't have the right somber stones apparently to level it up any. I also like the bleed. But I feel like an axe or mace would better suit me?
Iunno. I'm at a hump right now. I need to farm out a few more levels or something. I haven't moved past that Godrick zone. I'm still trying to finish Caelid. I think Limgrave is pretty much done.
If you like the bleed then try out a katana. They're really fast and have a similar rate of blood loss buildup. You have enough DEX to equip most of them. There is at least one in southern Limgrave that you can find. If you're attached to STR-scaling weapons then a mace is also an option. Not all of them have bleed, though. I know of one that does located in the area of the main continent south of Limgrave.
For somber stones you can buy them from certain NPCs.
If you don't want to leave Caelid to find those things, try removing some of your armor for faster stamina regen. If you find that you can't really tank any damage then there is no point in letting the armor weigh you down.
I just picked up the Uqitaitakiakia thing.
I thought I had to find somber stones, oops.
Or as I like to call it, the Uchi Gucci.
You can turn any weapon into a bleed weapon using Blood Ash of War. Not usually the optimal way to go about bleed, but if you like a certain weapon's moveset more than say katanas, there you go.
In Caelid your weapon should be around +10 (+4 for somber weapons), yours is quite low. You could be doing way more damage. Also I would recommend respecing with higher Dex if you plan to use a curved sword or uchi. Or your change your infusion to str or quality.
Alright. So that decaying dragon in Caelid. Been working on it from 11am to 530pm. I consistently get him down to 20%. I have to save three pots for the scarlet rot.
Its a total pain in the ass. I have to keep scrolling through my pots, to the thing the clears the the rot, feed my horse, to a health pot, to my horse where I have to answer a multiple choice question mid-fight. If I skip over a health pot, I have to keep scrolling again to find it. My summons are useless.
That sword is +5 now. I'll have to find more stones to get it to +10 then.
You're better off just not getting hit by his rot attacks. Trying to beat him while rotting and juggling different items is going to be very difficult.
Honestly, all but the legendary dragons in this game are super easy. You just ride around on your horse hitting them and just avoid their elemental attacks.
I don't want to tell you how to live your life, but this is unhealthy behavior and you should break yourself out of it. My new rule of thumb with Elden Ring is that if it takes more than an hour to defeat a boss, then I'm doing something wrong. Either I'm under-leveled (relative to my skill level) or my strategy is wrong. The worst thing you can do is get into that repeated loop of banging your head against a wall for 7 hours straight. Are you even enjoying the game at that point?
I just know I can do it. I just get tricked up or he does that rot thing right off the bat. If I stay at his left knee, he just spins in circles for the most part. Half the time I'm one or two hits from killing him.
I don't know that particular fight (I'm not far enough), but in the other Souls games I find it's really helpful to just give up and try again another day. Even when I'm dangerously close. Most of my biggest triumphs have come on early tries on totally different days than when I first attempted the fight.
What am I missing here? I need six Smithing Stone 2s?
correct, the number in brackets i.e. [2] indicates the "quality" of the item, so once you upgrade to a certain point you need the high quality versions
actually i remember thinking a few days ago that this system is needlessly obtuse and confusing at first... they should've made each tier of upgrades require completely different items, not the "quality" items just because it isn't intuitive. that's how it is in the actual Souls games iirc.
i remember it took me a very long time to realize what i was looking at the first time i played Bloodborne too, which uses a similar system.
There is another shortcut menu you can use, I'm not sure how it works on kb/m but on xbox controller it's accessed via holding the Y button - in the menus you can assign four commonly used items to it to avoid needing to scroll through your potions bar.
Did you use that Uchi at +5 or did you upgrade it further?
+6? I think?
I have a bunch of 4s and 5s I think. I didn't have any 3s. I need five more I believe. Then I can crank out a bunch. I forget which one I'm at, but I need five of them.
I think I'm confused on the map too. I thought we were supposed to go to Caelid after Limgrave. I'm tying to clear it. I did the castle at the southeastern end. There a dual boss in there that is going to have to wait. I can almost kill the lion thing, but that knight screws me up after it.
I'm going to move onto the lake north of whatever castle it is that Godrick was in. Work on getting some more smithing stones there.
+6? I think?
Lol that zone will be ez mode compared to Caelid.
huh. I thought Caelid was after Limgrave. Or are you expected to backtrack to areas?
There's a general questline that will take you through the areas in an appropriate way. You might want to pay attention to some of the NPC's you've found.
I hate story lines. I just mash the go button. Big thing that I like about the game, I'm not all tied up into chasing NPCs and following quests.
The typical path is Limgrave -> Weeping Peninsula-> Stormveil -> Liurnia -> Academy -> Underground -> Caelid I believe.
wat. wow. I really messed that up. haha, I'm like 80% done Caelid. I haven't done Weeping Peninsula I don't think. No Liurnia. No Academy. I don't even know what underground is. haha
You can play it your way. Ultimately, the only 'requirement' to beating the game is just having 2 great runes. That's it. However, the various zones have certain levels in mind, and there are a few major quest lines that will largely take you through the 'correct' path of zones.
I think you are meant to experience Caelid early, see the scary things and run away. At least that’s what I did. Nothing wrong with trying to tackle it before the other areas but it is a difficult way to do things.
Yea, I thought that was meant to be the next stop. I knew these games were intended to be difficult, so I just rolled with it thinking this is just the way it is. Difficult way for sure, heh.
Caelid is more of a mid game area. You are still early game it seems, you have about 80-90% of the content left.
mmk, that's neat. I do like the exploring and wandering around. I'm so stubborn that I get myself hooked on a difficult boss. I must have done that decaying dragon about two hundred times. A hundred sixty times I got it to about 20%. I knew I could do it, I just kept missing a swing, or it'd do that giant aoe deal. Reminds me of the raiding days in Molten Core and BWL. Its a good thing I don't do casinos. XD
A general rule I've been following is if I come to an area and whack something with my weapon, and it barely takes a sliver of life off of what I hit, I move onto another area, or continue exploring the one I wandered away from in case I missed anything. At first I didn't know weapons could be upgraded to +25 due to habits learned from the Souls games, so I thought I was in better shape than I was early on when I got a weapon to +10. You could also get through NG in most Souls games with a max SL of around 80-100. I'm thinking I'm going to be pushing 200 or even better by the time I'm finished with this game.
That's been my approach, too. If I'm doing zero damage to something, it's time to move along. At least for the most part, since I have basically zero sorcery and some enemies are only weak to it.
I have made it through a couple caves where the boss was mega powerful, but the rest of it was no big deal. I made it through one where the boss was two of those cat statues at the same time. Not only was it a heinous fight, my +5 twinblade hits were taking maybe 5-7% of their life per hit. I finally figured out how summons worked, and the dogs, wolves, ghosts, etc. were getting instakilled and inflicting no damage, too. I figure I'll come back there much later.
Stuck at Radagon now, after hitting a short roadblock at Maliketh. Gonna cool off and take out remaining world bosses and dungeons I passed over (except Malenia, she seems harder than when I first attempted in prior patch).
Oh, and what is this spell that looks like the magic special of Sword of Night and Flame? I was struggling so much with the sentinel before Maliketh I summoned a cooperator and he stunlocked that sentinel until it died and did massive damage. I thought he was gonna help me steamroll Maliketh, too, but he died real quick.
I didn't play with SpecialK mod for awhile. But after the reports of invaders crashing people's games, forcing you into a deathloop, and corrupting saves ---- I'm playing offline, so I thought I would use SpecialK again.
It definitely smoothes out the game, overall.
I typically find weaker enemies in a area to see how many runes I acquire to determine which area I should go to next, personally I try to take notes because of how massive this game is lol. But I have butchered quite a few questlines, that will be a bit easier next playthrough since they added the NPC markers on the map. I just reached Mountain top of the Giants, am RL110 180hrs played. I still feel have at least 20% of the game left. I think I will likely play this game the remainder of the year unless something incredible comes out. There's just so many things to discover and I have a lot of builds I want to try out.
That's where I am as well. I haven't followed any guide or anything, so I'm just winging it. Next character I'll plan out better. Probably even try a caster of some sort.
I do that a bit, but I also try to steal as much crap as I can while I'm there without getting killed too many times. :D
The game progression map may be helpful to have up on a secondary screen while playing.
I was playing ER blind without wanting to look at any guides, but then kept hitting low-leveled areas at a higher level (ie discovering Weeping Peninsula at lvl 60), and one-shotting everything is of course no fun
https://eldenring.wiki.fextralife.com/Game+Progress+Route
PSA for caves and catacombs and dark areas in general: buy a lantern and equip it on your pouch (the menu that appears when you hold down Y on the controller), and never have to fiddle with changing your left hand to the torch again.
Pouch is also great for summon sign items and other crap you wouldn't need in battle. Because the less equipped items you need to cycle through with the down d-pad in the heat of battle, the better obviously
The game can be launched in offline mode in the options. Invasions also do not happen while you're playing solo when connected online. Invasions are only possible when another player is summoned to your world, or you're summoned into another player's world. NPC summons do not enable invasions.
Lantern doesn't light up as much though, but yeah.
