NamelessPFG
- Oct 16, 2016
I remember that about a decade ago, I could hop on eBay and snag a brand new XSPC dual D5 bay res/240mm rad + fans/Raystorm Copper block/compression fitting/tubing kit for all of $175, most of which is actually pretty decent kit (except the compression fittings, they're horrible to try and thread the ring onto the barb with, just buy Bitspower and save yourself the pain and hours of frustration). Those days have long passed.
I thought EK was kinda pricey back then, and the nickel plating issues were in full swing then, so I knew to steer well clear. Even now, I'm a bit hesitant to buy their stuff, even if everyone else making an O11D XL front distro plate is charging about as much or moreso.
That said, while water-cooling costs a lot up front, you can generally carry most of your components forward with new builds. Radiators, pumps, fittings, tubing - it's not like those change on a regular basis, and even CPU blocks can often be adapted to newer sockets with some new mounting hardware. The only reason I'm buying extra stuff now is that I want to get a dual 360mm rad setup in my O11D XL (while keeping my old HW Labs Black Ice GTX 360 in my 800D that's about to house a Threadripper 1950X build) and also need a new res/pump combo that doesn't rely on now-nonexistent 5.25" bay mounting.
The one exception: GPU blocks. Their pricing in particular is especially insane when those don't carry over to new purchases like CPU blocks do. I was looking at waterblocking my RX 7900 XTX to get around the vapor chamber issue, but at $230+, I could've just returned it, got an RTX 4080 for the extra price, and enjoyed far better VR performance. (I actually wound up doing a direct trade for someone who was willing to waterblock it, and it's apparently running like a champ, over 3 GHz easy.)
The other exception: I generally favored 5.25" bay reservoir/pump units in the past, but modern cases give me nowhere to mount them. Now I can look at spending ridiculous sums on what are essentially thin reservoirs that mount where a radiator would, especially if they've got enough inlet/outlet ports to be billed as distro plates, double especially if they're meant to replace the O11D XL's front glass panel.
