I tested RAM, replaced GPU, replaced mobo, installed every ATI driver under the sun. Reformatted 5X. Exhausted all my options.
AMD Athlon X 3 450 3.2GHz
GIGABYTE GA-970A-UD3
Corsair 4G XMS3
XFX Radeon HD5770
Corsair 650TX 650W
You reformatted? That issue is usually driver related. I am skeptical that you reformatted.
I had a asus driver running in the background, windows installer was broken.
That's not possible because that's not how drivers work.
bull, DAODx.exe was a running process associated with asus mobo's.
http://vip.asus.com/forum/view.aspx...=Crosshair+III+Formula&page=1&SLanguage=en-us
DAODx or rundaod = a driver component part of the Realtek Gigabit ethernet controller install package
Image? It hasn't been stable long enough to image. Yes its SP1.
The Einsteins who replaced my asus mobo with the gigabyte didn't even reformat. I had a asus driver running in the background, windows installer was broken.
"its very time consuming to reformat if not necessary"
YOU HAD THE MACHINE FOR 4 WEEKS!!
hopefully that was the problem
unfriginbelievable
Blue screens are completely random. Can run for days with no instability.
We went from a saphire 5770 to a XFX 5770. Tried 10.6, 10.10, 11.7(current) 11.8, 11.11. I use driver sweeper in safe mode. I have not tried drivers from WU.
I'll run memtest all night. I have no other compatible ram but i think your right, i should just buy 8gig of Gskill.
Every reformat has been boot off the windows disk, delete partition etc.
Its the ram, not compatible with this mobo. I'm sure i can get it to work but just ordered 8gig ripjaws, its on the qualified vendors list. screw it ram is dirt cheap.
Dump files show a memory access problem.
4 passes, individual sticks no errors. RAM is set to 1.5V but HWinfo64 is showing 1.488V. Do i need to increase ram voltage? And if so how much?
no i didn't blend test
CORSAIR XMS3 4GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145251
What is the blend test? I'm running memtest now from a thumb drive.
