Firebug24k
- Aug 31, 2006
I've been assembling systems since the PC/XT days. And today I just did the dumbest thing I've done in the last 20 years. I was working in a rather dark corner, and I was installing a low profile PCI express card. I had to remove the low profile bracket since the case had a full height slot. Plugged it in, turned on the computer, immediately smelled smoke - a LOT of smoke. Yanked the power cord, took a very close look: I plugged the PCI-express card into a standard PCI slot. Yep. Fried the entire motherboard. Not sure what else has died, but there's a bunch of visibly burnt traces going from the PCI slots to who knows where.
Dumb.
Irony: The RAID card that caused the problem works perfectly still.
Dumb.
