Dumb question (driver related)
banjo5150
to start off, I always use the drivers from the manuf web site as if there is a problem the tech support wont just point a finger somewhere else. ( I never use the enclosed CD but download the latest from manuf web site)
Once its all up and running stable, you can look at who has newer drivers and play around.
I always get chipset drivers from the chipset manufacturer regardless of what the board manufacturer has on their site. Usually the board website is at least one revision behind. I usually download them ahead of time and then install them with my new OS install. I never use the CD either.
In this case, I'd download whatever the newest ones Nvidia has on their website, especially with a new OS like Vista. Since they are new, I'd update the chipset drivers regularly (every month or so as new drivers come out).
I have built a few PCs and I have always did what you said. I was just curious if it would better the other way.
