Seriously? That soon?![]()
I don't know when it will be out, I would think that most of the hard work has been done with the A3 core, just need to package WU.
I recommend a fan controller or adjust them in the BIOS if there's anyway you can do it. Love the case, BTW!![]()
Well.... if someone can figure out how to get the windows client to lock just on HT .
WinAFC might be able to do that but I'll let someone who has experience confirm it.I tried Bills PM but it wont let me assign the VM to just logical cores.
Iyou might as well think about just running native linux, which with that setup would be good for 22-25K PPD with just regular A3 cores.
HT doesn't work like that. You don't have logical cores and physical cores. All you have are logical cores, and each pair of logical cores runs on one of the CPU's physical cores. The core that a set of logical cores run on will divide its resources between the two logical cores depending on load. As far as the OS is concerned, there is no distinction between a logical core and a physical core.Well.... if someone can figure out how to get the windows client to lock just on HT or the VM to lock to just LC this was a bust.
The SMP2 client added about 9k. It however moved the -bigadv unit to a TPF of 53 min.
I hear that, I stuck three GPUs in my -bigadv boxen and my TPF went from 30:00 to 33:40. Thankfully the GPUs are doing around 22K PpD so the loss of points from bigadv doesn't hurt that much. I think it may be time to put a system together just for my GPUs.Edit, TPF went up to 38:48 from ~33:00. That is a loss of 5k ppd. Not worth running the 2nd client.
How did you assign the affinities? Can you try setting the VM on the first 8 logical cores and SMP2 on the next 8? Or is that what you did already?OK I don't have a TPF update on the -bigadv.... they take a while. But the SMP2 is running at just under 9 min, or 3500 ppd. Worth it if my TPF on the big adv stay around 33 min.
If the TPF on the big ADV does stay the same that would mean that there is a good big of CPU power that is not getting used. I'm wondering with all the stuff running though memory if I will lose 1-2k ppd on the big adv.
Tonight will tell.
Yeah, I know exactly where you're coming from. Only one of my -bigadv systems is running GPU clients. They draw a significant amount of CPU cycles. I see an improvement just from the difference between the 353s and 1888s WUs. I could imagine how much better that system would perform without a single GPU client and running native Linux instead of Win 7.I hear that, I stuck three GPUs in my -bigadv boxen and my TPF went from 30:00 to 33:40. Thankfully the GPUs are doing around 22K PpD so the loss of points from bigadv doesn't hurt that much. I think it may be time to put a system together just for my GPUs.![]()
ever get turbo to work in linux?
running just the smp -8 with no HT I'm guessing?Nope... I'm back in windows.
I wish a manufacturer would release an affordable (relatively) dual S1366 board that can OC, like a modern Asus PC-DL equivalent. Or at least, someone would come up with a way to OC this architecture like it was possible with Xeons in the past.
Yes, were it to be released at $500. The EVGA board makes the Skulltrail look run-of-the-mill by comparison, yet the latter's release price was stratospheric. I'm hoping it will be reasonably priced, but thinking in more realistic terms and looking at prices EVGA has on all its apex products, I wouldn't bet the farm on it.I don't know about affordable but evga should be releasing their dual 1366 mobo soon. I think I read something along the lines of $500. Given the cost of single socket enthusiast boards that doesn't sound too unreasonable.
True indeed, but I have not seen this happen since the BP6 days, and that was only possible because regular processors could run in dual sockets at that time. Shortly after, Intel prevented it to ensure their enterprise level products retained enterprise level pricing and exclusivity. If EVGA can pull a rabbit out of the hat, kudos to them and they gained a life-long customer.Now if only they could work voodoo so i could go get 2 microcenter i7 920s instead of spending $400 a piece on slower cpus I would be all over it.
I don't think your going to get i7 class procs working on a dual board. From what I've read dual proc systems need chips that have 2x QPI links (I think that is the term... on my phone) All the i7 chips only have one while all the 55xx xeons have 2.
It simply just won't work.
Custom bios would be great. But we would all have to decide on getting the same mobo or some one has a bunch of work to do.
I know it wont work. Thats why i said work voodoo. If they used magic I'm sure they could make it work.I don't think your going to get i7 class procs working on a dual board. From what I've read dual proc systems need chips that have 2x QPI links (I think that is the term... on my phone) All the i7 chips only have one while all the 55xx xeons have 2.
It could very well be Ubuntu causing your problems. I've read several bug reports stating turbo boost doesn't always work with 9.04 and 9.10 on some systems.Anyone know how to force turbo boost in Linux? Or do I need to switch distros?
