if only quad cores could increase a persons ability to research the facts before making judgements
Supreme Commander - none
Purely nominal advantage of QX6850 above X6800 or E6850 : first, four core processor in games did not give any special advantages ,Dual core processor with faster frequency show better result.
Even though the latest version of the engine is multi-threaded, there's no real benefit above two cores.
Oblivion performance is notably worse on Quad FX than with only a single socket AMD system due to the added memory latency
And once again, Quad FX doesn't do so well if all you're doing is running a single game; an Athlon 64 X2 setup is faster.
You have to read these articles closely to discover that:
# only a handful of games plan on using four-cores
# they won't show up for about a year
# the games won't take full advantage of all those cores
WE spoke with many developers including some big names and we learned that they can't make much sense out of quad or more core CPUs. They confirm that they can put two cores to good use but not much more.
Gaming fans, however, can confidently stick with the Core 2 Duo/Extreme or the legendary Pentium D 805. That's due to a lack of adaptations for four CPUs - in practice, only a maximum of two processors are used in games.
yeah , im sure there will be some games which will take the advantage of 4 cores in next 2 or 3 years,
but lets bring that lost planet test up to 1900x1200 resolution, put it up against a dual core and see if the spilled milk is worth crying over
Lets bring into play the low percentage of PC gamers that play at 1900x1200 and see if we give a shit.
The big leap was single to duo though, as everyone had to rewrite their code to get the speed advantage. From duo to quad though, there should be little to no rewriting necessary.
Tomshardware did a comparision between the two. Their test results showed that quads are in general faster than the dual cores - apparently due to the 8mb L2 cache. In their testing, the quads were on par with the duals at 200 mhz slower clocks.
I'm not saying it's conclusive, or absolute fact.
Crysis is being optimized for quads. That's reason enough for me to have one!
actually when it comes to gaming and pretty much everything else an overclocked quad will always win. Hell if it now comes to a game that is optimized for quads then the lead becomes bigger. A overclocked q6600 @3.5-3.6 will whallop a e6850 overclocked to 3.8 in single threaded and multithreaded apps. Mind you this is with a G0 stepping quad....
Exibit A :- http://www.xbitlabs.com/articles/cpu/display/core2quad-q6600.html
I'm waiting for a cheap refresh of the Quad D processors.
um, didn't HardOCP demonstrate Sup Com taking advantage of 4 cores?
/too lazy to look up article myself of course
I'm really torn on this myself since I plan to build at the end of year. Quad-core is the "wave of the future" but I'm very tempted to take a E6850 (or whatever) for the current punch of the higher clock speed. Thankfully I've got a couple more months to see how newer games handle quad-cores.![]()
yeah i wish, obviously that quad core didn't help you one bit ,
boohoo, so u found one game which performs noticably better on 4cores,
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2879&p=10
http://www.theinquirer.net/en/inquirer/news/2006/10/07/quad-core-is-useless-for-games
http://www.tomshardware.com/2006/09/10/four_cores_on_the_rampage/index.html
Get a Quadcore,if you run other things while gaming it'll help even more.I can fold,and game at the same time,or encode,and fold and game at the same time,try that on a dual core ?and see what kind of performance you get
The old fart with a Dell pre-loaded with bloatware is also "doing multiple things at the same time" whenever he boots up his PC. Guess he must be a hardcore enthusiast.
Every serious gamer tries to turn his PC into a console while the game is running
Wow, if you want to encode as you play games, you can't be considered a true gaming enthusiast.
The "proper" way to game has always been and always will be to shutdown every running process leaving only the game app. Extreme gaming is about squeezing every last fps from one's rig.
Multiple cores don't do anything significant in games. They are 80% hype and will stay this way.
Games will ALWAYS run great on single cores.
The CPU makers toss gamers a carrot and the gullible ones take a bite. Intel wants to make multi-core cpu's for business reasons that have nothing to do with improved performance in gaming. Do you think they are going to admit this in their marketing campaign? No, obviously not. They are going to spin multiple cores as the best thing since sliced bread. This is what they have been doing so far. It's hype. Why bite?
The Pentium 4 was the high mark of CPU achievement. There haven't been any improvements since then, at least from a gamer's perspective.
The CPU is becoming increasingly irrelevant. The future belongs to graphics and memory.
Fixed to demonstrate historical perspective.Games will ALWAYS run great on 640K.
