Drive Image Recovery
foxnews
I just back up my system by creating an partition image using Acronis True Image Home 9 and write to a DVD. I then use this software to create a boot cd.
When I booted from the CD and got into Acronis True Image, the sofware failed to detect any harddrive (SATA).
I did some research I found the following...
"Drive Image 7 will have problems finding the image file if the image file is on a HD connected to IDE3/SATA that is controlled by a seperate controller chip such as promise/SIS chip."
How do I fix this issue? I have Gigabyte DS3 board and Western Digtial 250GB SATA.
does this board has a separate controller which prevent Acronis True Image from recognize it?
thanks,
you have 4 SATA ports controlled by the intel ICH8 southbridge and 2 SATA ports controlled by a Gigabyte (jmicron) controller. See page 7 of your manual.
I dont have a clue but if your HD is plugged into the GSATAII0 or GSATAII1 ports (the ones closest to the pci slots amd controlled by the Gigabyte controller) you might try moving it to one of the SATAII0-3 ports near the front edge of the board that are controlled by the intel southbridge.
after booting from the Acronis boot cd,
1- if I choose Acronis True Image Home(safe Version), then it recognize my Harddrive with two patition but It did not list any DVD drive I have.
2- if I choose Acronis True Image Home(Full Version), then it won't recognize any harddrive or DVD with the error message: "E000101F4: Acronis True Image Home has not found any hard disk drives"
Currently my harddrive is plugged into the SATAII3, which should be controlled by Intel ICH8? from the manual, only GSATAII0 and GSATAII1 slots are controlled by Gigabyte chip.
gotcha yes, but the ide interface is also run from the Gigbyte controller, the intel chipset did not include any IDE interfaces so manufactures had to add a controller chip.
I have no idea how to make acronis reconzie the chip, the driver is on gigabytes web site but I dont know how/if it can be intergrated with the backup software.
sorry, Good luck.
I don't use Acronis but if you want some excellent drive imaging software, get a copy of Drive Snapshot. You can use it from the ultimate boot cd (www.ubcd4win.com) which should support just about any widely used controller out there.
Plug into the top yellow port, that will be SATA 0. The 4 yellow ports are SATA0-3, which are controlled by the Intel ICH8 southbridge, the 2 purple ones are the GSATA gigabyte/jmicron controlled ports.
In the Integrated Peripherals section of the BIOS there is a setting for SATA0-3 Native mode, try changing that, if it is enabled, disable it, or vice versa. In disabled mode the drive should be seen as a regular IDE drive to an OS, when that setting is enabled the OS sees the drive as SATA. The OS on the true image rescue disk likely doesn't natively support SATA, so that's where your problem is.
I'll try and let you know tonight. is there any difference between SATA0 and SATA3? they both are controlled by Intel SB chip.
either mode I chose (safe version or full version of drive image), it won't recognize my DVD burner. This dvd is connected to the IDE controlled by Gigabyte.
anyone has any idea how to make this Gigabyte-controlled IDE DVD visible to the Acronis Drive Image?
Anyone tried Symantec Ghost software to backup and restored partition from boot DVD?
Yeah I've used it before. It works, but I still prefer Drive Snapshot. I think I've got a copy of Ghost 2003 around here if you want it. PM me if you want some help with Drive Snapshot. I am using it on dozens of machines without issue.
I did some research on this issue. it turned out to be a common issue with the new chipset either Asus or Gigabyte.
Acronis True Image is an Linux based software and it dosn't have a new drivers for all new chipset.
I found a work-around solution and even better one. I used Bart PE which is a window-like boot up. I boot from Bart PE cd and see all drives (dvd or HHD). another bonus is that I can add software like Nero or Acronis True Image as a plug in and use it within Bart PE environment. it even has window-explorer plug in. it is like a mini boot window. it is perfect for recovering a crash or dead HHD pc Or bring the pc back to a clean state without wasting time reinstalling window/drivers/app over again.
Bart PE + Acronis Drive Image + Nero = the best ultimate recovery solution. Now I am not afraid of virus or dead HHD.
Bart PE is an awsome life saver software which I ever discover. and it is beyond this site forum discussion.
