Hard_Rocker said:
my suggestion, for the interior... I know you don't have much space in it, and you'll only have that small window... I think you should have two lights inside, a "normal" white light and some kind of UV/blacklight. When the normal light is on have the interior appear fairly normal... but, all over everything you'll have splashes of UV paint (clear as possible, I dunno what's out there) for "blood", and a big pentagram somewhere visible...
so what happens, is the normal light is on... then when the monster pops out of the top or whatever, the light switches off and the UV light comes on... but the UV light MUST be flickering, so it's a dark interior with the "blood" and the pentagram appearing to flicker in the (simulated) damaged base lighting...
I think that'd be cool but I dunno how you'd get the UV light to flicker...
just my 2 pence...![]()
Sobek said:I'm curious as to which type of model kits you are bashing for parts. Do you just go to a hobby store and find the cheapest kits there or do you look for specific types of kits like ships? Also, can this styrene plastic stuff be baught at most hobby stores?
CrimsonSky said:I looked into a miniature projection device to no avail--would be great to have the window like a rear screen material and project images on it--anyone have the technology here? we need optical engineers! Maybe we can find a lo-tech solution
cgrant26 said:Was this the direction you were looking in?
http://www.atbatt.com/product/ItemID/3220.asp
http://www.ndsproducts.com/misclaserpointers.html
V0ltage said:wow![]()
this could very well end up being one of the best casemods EVER!
CrimandEvil said:I just thought it would so cool if you replaced the rod with tubing and use it in the WC setup. Then again that might not work. Still it looks cool.
JrCamacho said:
JrCamacho said:
MAXX RS4 said:He just picked his balls..![]()
CrimsonSky said:I wasnt picking my balls, I was adjusting my testicles.![]()
naw dude i was a little immature. plus you might want to watch how you talk when your talking to modsPC_Commando said:come on FLECOM there just having a little fun dont be a butthead
