Matches said:Geez, and to think I was real happy with myself when I installed a new RED LED fan...
Snakebyt said:best case ever... great work
Well maybe someone could use that in a DNF casemod. Unfortunately we'll never see the finished productDarth_Fluffy said:And I remember playing Duke Nukem 3D, and in the church chapel there was the dead marine from Doom in the secret. This is just as relevant.
vexter said:This might be an understatement.
I rarely look at a case mod and wonder "how did he do that" But yours is so far beyond any ability that I have. Do you do some kind of miniature building for a living? If not, maybe you should look into it.
wolrahnaes said:Crimson: fsckin amazing work. maybe i missed it in all the discussion about the case, but what hardware will be in there? since nV is pushing their card as the best for D3 (rightfully so for now....i guess...) can we expect a 6800 in it?
PlagueH4 said:awesome mod, like all others you made. when are you planing to update your site Crimson Sky?
IdiotBoy said:I gotta say man, simply the greatest mod I've ever witnessed...and it ain't even done yet!
But I got a question that wasn't explained in detail in the worklog. How exactly did you make the airlock doors and casing? I mean, the actual plastic portion....Did you make specs and send it off for fabrication? I don't see how you could have made them yourself so perfectly!![]()
vexter said:I rarely look at a case mod and wonder "how did he do that" But yours is so far beyond any ability that I have. Do you do some kind of miniature building for a living? If not, maybe you should look into it.
CrimsonSky said:It was all done by hand using various plastic sheeting. No drawings, no specs, the pattern was laid out in my head, and then with pencil on the plastic. Tools used were utility knife, Dremel drum sanding bit and a pencil. It's all glued together with cyanoacrylate adhesive--basically superglue.![]()
IdiotBoy said:And this is exactly why I could never ever build anything nearly as cool as the scraps left over by building this amazing wonder of art and technology!!
I could not fabricate pieces like that by hand with just the design in my head...it would most likely come out looking like some demented 5-year-old's ashtray/sculpture they made in art class.![]()
Outcompute_123 said:Crims, I was sitting here at work, thinking about your mod.
The flashlight comment came to mind.
Did you have any plans to fabricate say, mini spotlights into this? Or something along the lines of a static lighting fixture?
