- Jul 1, 2004
http://www.gigabyte.us/products/product-page.aspx?pid=4567#ov
I don't know if solid state capacitors are ALL made in Japan or what the deal is.
I used to install this guy from gigabyte:
http://www.gigabyte.us/products/product-page.aspx?pid=4315#ov
as you can see, it clearly says "All Japanese Capacitors"
but rumor has it that this motherboard is being discontinue as Intel is killing the G2030 CPU.
So Gigabyte is asking people to switch to the B85 (first link), in which it DOES NOT state "all japanese capacitors" on the motherboard. Rather, on the website, it says "GIGABYTE uses All Solid Caps (Capacitors) and Low RDS(on) MOSFETs which are rated to work at higher temperatures to provide a longer lifespan."
but is it made in Japan though? If not, where else made Solid Caps?
