VanGoghComplex
- Apr 5, 2016
So I'm dream-planning the next iteration of my rig, and the case I'm eyeing has room for a 560mm rad. It's also got room for that rad to be extra thicc, so I'm toying with the idea of an Alphacool Monsta.
There's three bits of conventional wisdom I've seen with radiators:
1.) Go as big as your case will allow
2.) Thicker means more surface area for dispassion
The third bit is what I'm worried about, because I do not want a push-pull config.
3.) Thicker rads are harder to get air through, and lose efficiency if under-fanned.
Will an 80mm thick radiator cool less effectively than a 30/45mm radiator, assuming the same FPI and push-only fans?
