Do I need to upgrade my PSU
nxcess
I've been experiencing random crashes while playing Starcraft II. I'm assuming because this is the only game I'm playing that runs my system at 100%.
system specs:
DFI UT P45 T2RS // E8500 // Corsair Dominator pc2 8500 2x2gb // 2 x WD 640 AALS // 2 x XFX 5770 // Silencer 610 PSU
overclock settings:
cpu @ 4ghz // cpu voltage @ 1.264 // fsb @ 500 // memory ratio @ 1:1
psu rails:
+3.3@24A // +5V@30A // +12V@49A //-12V@0.8A // +5VSB@3.0A
According to Guru3d, I need at a PSU with more than 55 amp on the +12volt rail. I want to be sure this is the issue before a put the cash down for a bigger power supply. Suggestion?
You don't need to upgrade your PSU. It's more than enough for your current setup.
Your random crashes might be related to the GPUs you're using. I.e one of them is defective or SC2's XFire scaling is crap. Or even overheating.
It could also be related to your CPU OC. You might need more voltage.
Your OC SHOULD be fine, try disabling crossfire.
Crossfire issues in SC2 (beta Phase 1) shoed me from two HD5770 to a single HD5870 (dead spots were the most annoying).
OR try Catalyst 10.7a, which has specific SC2 enhancements.
I've already tried adding more voltage. It doesn't seem to do anything. Some days, it'll crash while playing SC2. Usually in the same spot / timeframe. If I wait the next day, I'll play through it and some more w/o a single crash. Too random to narrow it down to a specific component /settings. Only thing I can't test is the PSU.
I like eyecandy. =D I've been having driver issues with crossfirex ever since I got it. I get weird glitches depending on the games I'm playing and the driver version I'm on. I finally got everything to work right with 10.4. Then I started playing Starcraft and had the dead spots / missing units. Upgraded to 10.7a, it fixed it but then I started experiencing crashes after that.
I
Then the next step would be to remove the second card and see if the system is stable.
Any benchmark tools that'll put the same load on my system as sc2? Need something to load the CPU and GPU at max.
Not exactly the same load but still pretty stressful:
Use Prime 95, OCCT, Orthos or Intel Burn Tool to stress test the CPU.
Use Furmark or ATI Tool to stress test the GPU.
Are you positive your OC is stable?
I left it encoding video files to dvd for more than 8 hours before. Gotta love batch script. That's a good stability test for me. Intelburn in test set to max load. Name the benchmark and I've pretty much ran it through the system fine. Been running fine for over a year with an 8800GT and a 4850. What I haven't done was to load the CPU and GPU to 90%-100% at the same time. Didn't think that would have made a difference til sc2 started crashing.
What's the power draw for 2 5770 reference cards? Wattage and amps. What about an e8500 at 4ghz. Voltage fluctuates between 1.248-1.264. Vdroop enabled.
I doubt your rig draws more than 300-350W at max load. I don't think your PSU is the issue.
Have you tried running memtest86+ ?
Memory isn't overclocked. It's running at 500mhz 1:1 with the fsb. It's not crashing during anything besides sc2. If and when I do bsod, it'll display ati(something).sys bsod. I'll check the crash dump when I get home for the exact file name.
As has already been said here your PSU is most likely NOT at issue here. The Silencer 610 (A Seasonic build if memory serves) is quite robust and perfectly capable of handling your system with a bit of power to spare.
Starcraft II is the biggest pain in the butt when it comes to SLI/XF configurations.
Tell me about it. I'll start testing with a single video card to see how it goes..
