Do all motherboards have...
Cyco2oo3
IDE inputs? I've been looking for a cheap motherboard that supports my Intel Celeron D 2.53GHz (Socket 775). Also, is one of these another name for IDE:
PATA, SATA, SATA RAID
Ok, it says the motherboard has two PATA ports. One is blue and one is white. Do the colors make a difference at all?
No.
Also, keep in mind, 2 devices (ie. 2 optical drives) can be used per one port. So you have room for 4 devices total.
Thanks. And, just out of curiousity, some boards can have one PATA port on the bottom and one on the center-right?
Yes and No...I have a mobo that wants an IDE boot drive to be HD00 any other postition and I get a "non bootable disk" error. Most of the time it should't though...but chances are the blue ide port is for HD00 and HD01, your master boot drive.
also I *think* you shouldn't mix HDD and CD/DVD-Roms on the same data cable as I've heard the CD/DVD-rom can slow the HDD transfer speed
For all general purposes, PATA and IDE are the same.
The only issues that I've seen concerning the quote above is when you've got two CDRW drives on the same cable, and you're ripping from one and burning to the second drive. Other than that, I don't believe there is any noticable degradation of data transfer speed by having a CD/DVD device on the same cable as the HD.
Ax
Some boards have IDE RAID capabilities...personally, I just used it as an extra IDE channel rather than for RAID.
