michalrz
- Jun 4, 2012
Hey! I've integrated this measuring thing of mine into my experimental solar setup, so if anyone wants a Rpi4 tweak tested feel free to let me know
Raspberry Pi Zero 2W | Raspberry Pi 4B, 4GB model | Raspberry Pi 4B, 2 GB | |
RAM | 512 MB DDR2 | 4 GB LPDDR4 | 2 GB LPDDR4 |
Price | 100 Złoty PLN (equivalent to like $25 USD) | 400 Złoty PLN (equivalent to like $100 USD) | 300 Złoty PLN (equivalent to like $74 USD) |
Power consumption with 100% load - 4x concurrent World Community Grid OPN tasks | 0.5 A - 2.51W | 0.95 A - 4.70 W | 0.95 A - 4.70 W (assumed same based on the 4GB model) |
Power consumption while idling (VNC/SSH session) | 0.17 A - 0.88 W | 0.49 A - 2.45 W | 0.49 A - 2.45 W (assumed same based on the 4GB model) |
CPU | ARM Cortex A53 @ 1.0 GHz | ARM Cortex A72 @ 1.5 GHz | ARM Cortex A72 @ 1.5 GHz |
PPD (WCG, 10 days average) | To be calculated, will edit it in here in a few days (temporary filler info: day 2 it's sloooow) | 6394,3 | 6394,3 (assumed based on RPI 4GB) |
I'm not a pi expert, but I think that was just the first version of the Pi Zero. michalrz is using a Pi Zero 2W (which it looks like is a new model that just came out within the last couple months) which is listed as the following - "With a quad-core 64-bit ARM Cortex-A53 processor clocked at 1GHz and 512MB of SDRAM, Zero 2 is up to five times as fast as the original Raspberry Pi Zero.". 512MB of RAM still though is then probably even more of an issue if trying to run 4 tasks at a time instead of 1.I’ve looked into the pi 0 before. You should see roughly pi 3 performance if I remember correctly. 512mb Ram means you’ll probably need to run with zram to stretch Ram enough though.
Edit to note that while per core performance is similar to the pi 3, the pi 0 only has 1 core clocked about 20% slower, so you would need 4 pi 0s for the same ppd output.
That's correct, it's the updated one, with a quad-core (4x 1GHz) ARM chip.I'm not a pi expert, but I think that was just the first version of the Pi Zero. michalrz is using a Pi Zero 2W (which it looks like is a new model that just came out within the last couple months) which is listed as the following - "With a quad-core 64-bit ARM Cortex-A53 processor clocked at 1GHz and 512MB of SDRAM, Zero 2 is up to five times as fast as the original Raspberry Pi Zero.". 512MB of RAM still though is then probably even more of an issue if trying to run 4 tasks at a time instead of 1.
Well dang - I totally missed the announcement of another pi 0.I'm not a pi expert, but I think that was just the first version of the Pi Zero. michalrz is using a Pi Zero 2W (which it looks like is a new model that just came out within the last couple months) which is listed as the following - "With a quad-core 64-bit ARM Cortex-A53 processor clocked at 1GHz and 512MB of SDRAM, Zero 2 is up to five times as fast as the original Raspberry Pi Zero.". 512MB of RAM still though is then probably even more of an issue if trying to run 4 tasks at a time instead of 1.
Pi 4B 4GB | Pi 4B 4GB | Pi Zero 2W | Pi Zero 2W |
5834 | 6072 | 2123 | 2017 |
4.7 W | 4.7 W | 2.51 W | 2.51 W |
Not me, but I been playin with a couple orange pi's, rollin some Einstein stuff:Anyone been playing with raspberry pi 5s on raspbian bookworm?
