Some builds require it, mostly used with Endless walk set, F/R sets do not use Unity.
I digress though, I am at the limit of my monk knowledge, I only ever used monk for WoL farming build, never used her to push anything.
This build using no Essence so your essence is always topped up. The secondary stat on that weapon isn't used since you aren't using Bone Spikes.Still needs to research into Necros, I assume that is a generator build of some kind, judging by the weapon's effects and your Aquila's Cuirass cube?
As much as I loved PoE, the map system and Grift system are not that different in terms in its actual implementation (you grind maps to do more maps, just like you grind grift to do higher level grift), with its own what I consider flaws. The mapstone drop system is much less likeable in my opinion than Grifts, because your map progression is entirely dictated by the maps you get as drops, unless you want to go shopping for them. At least on Grifts, I can choose my own difficulty, rather than having some item (or lack thereof) preventing me from doing so. I lost count how many times I couldn't progress through the atlas because the map stones simply refused to drop for me, and after a while, it just got old and I couldn't bring myself to grind anymore. I was hoping I'd have the motivation to at least meet the end game boss (Map maker guy, I can't remember its name), but after I think the 5th time the game stopped me from progressing as my last high tiered map gave me no maps and my next map was 3 tiers under, I quit the season.
For all the praise it got, the map system is really just the same thing different skin, so for a game that has been touted as the D3 killer, I expected something more than that, unfortunately I found it rather disappointing. PoE certainly isn't as bad as I made it out to be, and I enjoyed every minute of it up until I reached the maps, then it went downhill from there.
I'd go back and play 3.0 at least once, but how far will I progress through it, I have no idea, especially if the end game is same as before (I haven't looked a lot into 3.0 apart from the unified difficulty, since my attention is now completely off ARPG's).
So for what they are, I enjoy both D3 and PoE, but for actual 100 hour binges, PoE doesn't have enough to hold me for that long. D2 and even D3 does a better job at it.
I'm using the same build and was able to solo GR65 with no problems. I just have to work on building up my Paragon points.This build using no Essence so your essence is always topped up. The secondary stat on that weapon isn't used since you aren't using Bone Spikes.
Most of the damage is done by your primary, Grim Scythe with Corpse Lance as single target damage.
I think it's the strongest Necro build right now. The set used is Inarius.
https://us.battle.net/d3/en/profile/Zepher-1253/hero/91353912
Oh, the belt I am wearing is for speed grifting, normally you wear the Dayntees Belt for damage reduction with Decrepify.
I switched over to the OCN clan a couple of years ago since the H clan wasn't very active.Zepher getting shaky yet? Hey btw, are you in the [H] clan? I'm just curious since I'm on a lot and like to see where I'm at compared to others.
Right on, I will.I switched over to the OCN clan a couple of years ago since the H clan wasn't very active.
Zepher#1253 is my BN account feel free to add me.
This is my build, https://us.battle.net/d3/en/profile/Zepher-1253/hero/91353912Same, that was fun. Thanks guys.
What spec were you two running? I just got 6pc Inarius on my Necro and the bone storm build is a lot of fun. Reminds me of a Druid in D2.
Ran around with Zepher for a bit and raided treasure rooms. Crazy loot was dropped! My tag is Stryderxx#1390 is you want to add me to your friends list.
I was running my Witching Hour belt and Nemesis Bracers with you guys since we weren't doing 70+ GRifts.
I was trying Rathmas set and have a hard time with T13. I just keep dying all the time.
Zepher was running Inarius with me. He must be trying a different build. Inarius with the 6 piece bonus has over 100 million toughness once bone armor is at 15 stacks with the Wisdom of Kalan.Inarius builds have a crazy amount of toughness, I'd try that if you have the set. Or you can try to get a couple Unity rings if you don't already. Cube one and put the other on your follower. It was pretty much required on my Monk for T13/GR60.
I like the Necro playstyle more than the Monk, though I can only muster ~GR55 compared to GR69. I think I'll try something else Thursday when the new season starts, maybe a Barb or DH.
