Well, after getting a basic copy of XP installed and getting the drivers installed, running GPUz I saw that the video card was running in 1x mode... I read up about this problem earlier and remember seeing people talking about flashing the bios.
So, I install the "EZFlash" utility off of the mobo page, found the BIOS update, unzipped the files, w/ the utility I found the .bin file, and I checked the boxes to auto-restart, etc.
So it's going through the process, backing up, etc etc, and then my mouse stops moving at around 20% progress, but the screen is still updating... so I'm like "okay...." so I let it churn some more until the screen is totally frozen and I'm like "fffffff".
So, having no idea what to do, I reboot it, fuck, nothing. It turns off and it turns on again and then off again and will continually cycle. The little POST screen's reading ending up either E9 or 63... not sure which way to look at it. I tried clearing the CMOS w/ both jumpers, etc, and still, the same thing.
What can I do now?!! If I can remedy this, what should I try next? That piece of software seemed waaay too flaky... I should've known better.
