Ieldra
I Promise to RTFM
- Mar 28, 2016
So instead of directly responding to what I typed you instead infer horse dung from it.
First the fact is that I said BOTH DEVS AND IHV ARE RESPONSIBLE.
What you state:
ONLY THE DEVS ARE RESPONSIBLE.
That is utter BS unless:
THE DEV HAS NOT REACHED OUT TO AMD nor NVIDIA NOR USED ANY TOOLS SET FORTH BY EITHER.
Can you prove this last statement? Can you prove AMD or Nvidia have had absolutely no contact with Square Enix for this title? I mean that is what you allude to. It is seriously asinine and just shows that most of what you post is garbage and not to be taken with any less salt than WCCFtech.
1. Pretty sure you bitch and whine every time NV works with a game developer, some irony in you demanding this be the norm now.
2. AMD/NV are under no obligation to help anyone... Why would they use their resources to help individual developer, essentially writing parts of the code for them? They've already done the optimization work, use DX11.
Do Intel/AMD dedicate their resources to helping random developers programming in assembly? Is there a dedicated team of assembly assistants? No. They focus on optimizing the compiler, if you're going to program in assembly you are on your own.
You've been using the word asinine very frequently, maybe put down the thesaurus and start making sense instead?
