Design me..
rob24
Design me a resonable, good, fast, set-up.
Currently I have $500 and all im willing to spend.
I need..
AGP 8x motherboard (to support 6800gt oc)
AMD Athlon 64
DDR ram (prefierable corsair xms)
Powersupply
Also Im looking for a good power supply that can power all the things mentioned above. Powersupply my brother will be buying me so dont take it away from the $500 that im spending.
Assuming you get this MB for $130 or so which is generally considered to be the best.
http://www.newegg.com/Product/Product.asp?Item=N82E16813130468
You can get a 3200+ Venice processor for $204
http://www.newegg.com/Product/Product.asp?Item=N82E16819103535
And then you have $165 or so to spend on some RAM. I'd get at least 1GB (2x512) with a tight timing of 2-2-2 or 2-3-3. Some examples...
Patriot
http://www.newegg.com/Product/Product.asp?Item=N82E16820220006
G.Skill
http://www.newegg.com/Product/Product.asp?Item=N82E16820231012
OCZ
http://www.newegg.com/Product/Product.asp?Item=N82E16820146896
Corsair
http://www.newegg.com/Product/Product.asp?Item=N82E16820145449
I like the OCZ Powerstream 520 myself for a PSU. It's a little pricey ($135), but it works like a charm.
http://www.newegg.com/Product/Product.asp?Item=N82E16817104152
You should be able to OC that setup to 2.6Ghz I would imagine pretty easily.
Whats the difference between a Venice and a Winchester? Which one is considered.. better.
so is this what im hearing? Venice>Winchester>Newcastle? correct me if im wrong.
