Hardcore2012
- Jun 17, 2012
Dell always charge a load more than most retailers in the UK. PCBuyit seem to be trying to cash in on an exclusive. When it hits Amazon and the likes then we'll see some proper prices.
The U2713 is on the uk site now at £610.80.
http://configure.euro.dell.com/dellstore/config.aspx?c=uk&cs=ukdhs1&kc=305&l=en&oc=U2713HM-Black&s=dhs&sbc=dell-u2713hm
I refer you back to my earlier comments on the retailer: http://hardforum.com/showpost.php?p=1039018561&postcount=146Eh, that's not Dell's site, so I don't give much weight to the price they have.
Probably not as much as I expected, hopefully that means there is still plenty of scope for the pile 'em high sell 'em cheap type sellers to get more competitive deals. HP's ZR2740W & the U2711 are both available for less than £450. The cheapies (Hazro & Digimate) are £380, and the Korean imports are sometimes even less.The U2713 is on the uk site now at £610.80.
Usually. Sometimes computer components aren't too bad, but Dell monitors in the past have been grossly over priced vs USA.UK just seems to get screwed over on electronics?
Question is, would a GW2 and TF/ CS player notice 22ms input lag? Coming from a Nec 20WGX2, I mean, I would guess this already has 10-30ms of input lag?
But I think the U2713 will be my next screen anyway
Your NEC doesn't have any input lag, all of input lag measurements from the 20WGX2's era are wrong. The U2713 has 15ms of input lag when measured with an oscilloscope. It will feel a tincy bit slower if you are sensitive to input lag.
Seriously considering this screen to upgrade my U2412 when it's more readily available in Canada.
I've grown to love the look and feel of the 2412, but the lack of I/O ports (specifically HDMI in and Audio out) just kills me. Also I purchased a new desk which puts me almost 3ft away from the screen so the 27" might be a better fit.
Hope you have good eyesight. Text is going to be pretty small at that distance.
I usually view from 2 - 2.5 feet away from display and I can clearly read this message while keeping IE 100% zoom. I can even read welcome message on top while staying 2.5 - 3 feet away
I am with MentatYP on this one, and being able to read something, is a far cry from comfortable for long periods.
I also sit about 3 feet away from my monitor, and while that is in my comfort zone with my 24", when I had a Dell 3007-HC for a week I constantly found it tiring to read small text from the smaller pitch, and found myself leaning in closer a lot. That pitch is larger than one the 27" screens. I have better than 20:20 vision. It wasn't blurry, it was just small.
But I think most people sit closer than 3feet so less of an issue for them.
