I saw the embarrassing contrast ratio rating of 1000:1 and quickly moved on. But hey at least Dell is honest.
1000:1 is a very good CR.
However, it says little without viewing angles and measured black.
CNet didn't say that.
Interesting to compare with the iMac 27": similar panel? WG or not? LED BL or not? What LED with what gamut?
BTW iMac has glow.
On the Dell U2410, when viewing dark gray in the SRGB and Adobe RGB presets, we noticed apparent static dithering. We didn't see this dithering at all on the U2711 in either RGB mode or in any of the other presets. This should come as a relief to consumers that viewed this flaw as a major sticking point on the U2410.
The optimal viewing angle for a monitor is usually directly in front, about a quarter of the screen's distance down from the top. At this angle, you're viewing the colors and gamma correction as they were intended. Most monitors are made to be viewed only at that angle. Depending on its panel type, monitor picture quality at nonoptimal angles varies. Dell used an H-IPS panel to make the U2711, which usually shows only minimal color shifts with angle changes. On the U2410, we noticed a faint white glow when viewing dark images at off angles and a dark shadow when viewing light images in the same way, about 120 degrees to the left or right and even less from above. The shift isn't as dramatic as with a TN panel, but it was slightly more dramatic than with the 2408WFP; however, its color didn't shift as much as the perceived brightness did.
I have seen the iMac and it does have white glow, but it is much less then a 3008wfp.
is /will this be the best 27 inch lcd dell makes?
$1049? lolno.
You think that's bad? Try the UK, the U2410 is listed as £499 (ex tax & delivery), in the US it is $499 . Now with the current exchange rate of ~1.6 and Dells math's, that would make the U2711 go for the equivalent of $1678.
Thanks Dell but I think I'll just buy the bloody iMac or the Nec.
Ps: I refuse to take part in Dells panel Lottery
Wide-gamut, probably another terrible "sRGB" mode, way overpriced, and probably the same dirty looking anti-glare coating...
Might as well buy a 27" imac and use it as a display at this point..
edit; actually, the NEC's with this panel might be priced about the same, and will probably be a lot better. Does Dell really think they can compete with NEC?
I totally agree.
-Ugly display
- Important Depth ( for a 27" you can't use it at 30cm)
- No LED...
- Wide Gamut
- Grainy Coating
- 1050$ ! (and 1050 according to dell conversion)
Now we have to wait for an hypothetical 27" Apple Cinema Display (Imac is great but it's not really cheap when you don't want to change your computer...)
Omg...that's ridiculous. For $1678 the panel better cook, clean, and dance.
Hi,
are you sure that NEC will make an LCD with this panel? Do you know it’s price?
In this thread you are comparing the Dell with an hypothetical NEC that does not exist…..what's the point?
Bye!!
Yes, it has been confirmed. NEC released a pdf a month ago or so listing off one, or possibly two displays that are going to be using this panel. It was posted in a thread here, you can dig it up if you want to confirm.
There are no IPS monitors with a contrast of significantly > 1000:1. TN and PVA monitors can crack like... 1200:1. You know those 50,000:1, 100,000:1 to numbers you see? They are all 'dynamic contrast' marketing BS, the panel is still only capable of ~1000:1 (in most cases, less).
Oh I know about all this I guess I'm just spoiled by the CR of my Plasma. (tested 2,700:1 ANSI contrast) but I could've sworn newer LCD's achieve 1,500 - 2,000 actual CR as well.
EDIT: Ok I found one, the Dell 2408WFP was tested @ 2568:1 CR / 0.06 Blackpoint using it's Dynamic Contrast ratio feature (auto adjusts backlight brightness) I guess this feature is sort of a "trick" to achieve these numbers but TFT Central says the feature works well with movies & games. But It's a shame the 2408 has the worst avg. input lag results of any monitor. (64ms!).
This is true with all S-PVA panels; better blacks and worse input lag. The static CR of the Dell 2408 is still 1000:1. The static CR of the new U2711 will be the same, so the difference is minor at best.
Dave
PS: Try testing the input lag on your plasma...
I wish they had actually run the input lag tests instead of saying it had no noticeable input lag. I'd rather have an objective measurement than a subjective statement.
I'm gonna go ahead and call it early. Best. LCD. Ever. Because I absolutely trust CNET reviews 100%But seriously, it's looking pretty good so far, isn't it? 27" IPS, highest res in a 16:9 (would prefer 16:10, but 2560x1440 softens the blow), matte, dual DVI and DisplayPort. It's like they reached into my brain and made almost exactly the monitor I wanted.
I can't call it Best.LCD.Ever until it's on my desk and I've played MW2, Borderlands, Mass Effect 2 and then watched Star Trek on DVD, some video rips, and HDTV sports on it.
Actually, I plan on buying 2.Cool! Once the Dell U2711 is release please purchase it and do an awesome review for us with lots of pictures!![]()
Best. LCD. Ever.
Except for the price? I hope in your wishlist at least, you were hoping for all that AND a sub $700 price.
Took a look at a 27" iMac next to a 30" Apple Cinema Display at the Apple store the other day. The 30" still seemed to have significantly more screen size to me. The 27" didn't look much bigger than my 24" (Dell 2407).
Its just your eyes doing funny things to your brain because the difference in screen size/screen real estate between the 30" and 27" is actually much smaller than the difference in screen size between the 27" and 24".
Nope, he is right. You are forgetting. The 27" is 16:9 and that makes it much smaller.
The 27" is barely bigger than the 24" except in width. While the 30" is a big jump in both dimensions.
And it just isn't in vertical, total area is +20% 24" vs 27", but +30% 27" vs 30".
Check it out:
http://tvcalculator.com/index.html?b6099e4f60a5ee33e7c6cec0278bdac0
Uh are you talking about physical monitor dimensions or actual useable on screen space? Because if you're talking about the latter the difference between 24 and 27 is much more than the difference between 27 and 30...
Check it out:
