How long did it take you guys to receive the monitor from Dell?
I ordered last Sunday and it was due to arrive today, yet it's still "In Production"
(from ON, Canada)
I bought a new graphics card with displayport connection and the monitor goes straight to sleep now! - No cable not detected warning message floating around for 5 minutes
have you set it to the correct output/ plugged it into the input and not the DP Out? Have you enabled Display Port 1.2?
@Lava Lamp Freak
I still haven't received it either :/. I tried calling Dell 3 times yesterday and I was transferred three times and then cut off after a 15 minute hold, or end up connecting to someone typing away on their keyboard and not talking.
I ended up emailing them and just received a mail back that it will take 1-2 days for them to contact the manufacturing facility on the status...
I'm now praying that my panel will not be defective at all. It might seem like a nightmare to RMA with Dell
I finally got a shipping notification today. I should have it on Tuesday.
So.. any one tried out daisy chaining these monitors?![]()
Mine are daisy chained....just make sure to turn on the DP 1.2 setting In the osd on both screens otherwise only one will work. Also having a GPU that supports DP 1.2 helps obviously![]()
So the output that connects to the first monitor has to be DP 1.2?
I've got a gtx680, which has a DP 1.2, and late 2013 rMBP which should also support it.. But I'm looking at getting a DP KVM switch to use with these machines and 2 of these monitors.. I have absolutely no idea if the KVM switch has DP 1.2.. altough I highly suspect it doesn't. :/
My monitor arrived today and it's a rev 00 November 2013
Been using it for 4 hours and havent had random shutdowns or noticeable backlight bleed yet... but I've been having issues getting it to work with the display port cable they gave. I've never used display port before, so when i plugged it into my Asus 7850, it didn't detect it at all. I just gave up and used an HDMI cable.
Coming from someone with no experience with IPS panels and previously used a nasty green-tinted TN panel, I gotta say this looks absolutely amazing. The build quality is superb. I just hope I don't stumble on something undesirable right now.
Good day to you, owners of the U2414
I am looking for a new GAMING screen. I will be playing MMO's and RPG's on this screen. For a 60hz screen, is this one decent in the blur department? As in, not much worse as a regular TN panel?
I've owned a Dell U2312HM and the blurring was kinda distracting on that one so I was hoping this one is better.
Or is this screen not really meant for gaming?
Thanks in advance!
Also can't get the dell software to pick up the monitors in windows 8.1
Does the glass panel cause a lot of glare, or is it also treated with a light matte coating?
What glass panel?
Am I misinformed? Is the display panel itself not seated behind a glass panel? I haven't seen the monitor in real life, but that is what I gathered from the images I've seen.
AFAIK, Dell Display Manager only works with DP 1.1 (option in OSD). But DP 1.2 is required in order to daisy chain these monitors.
It's all about trade-offs these days.
@Christian88
I have the exact same looking problem. I can't tell if the bottom left is backlight bleed or just ips glow. I was considering RMA but it seems like it affects the whole line :/
I am returning mine. I don't have the patience or opportunity to be without a monitor for so long. Really disappointed by this.![]()
