My DELL S2740L came this weekend. So if any1 has any questions, i'd be pleased to answer them. I'd like to test it, but aint got any free time now so feel free to ask
Hi,
I joined the forum just to share my going-over these two displays with you guys..
Please note that is how I saw the monitors in the store!
And this is a comparison between the two and not a review "I don't own any of them YET"
## S2340M
- Pros:
o The colors are so alive and far from any PC monitor Ive seen before
o Sharp and crisp pictures
o Wide viewing angles
o Stylish with very elegant gray bezel at the bottom
o Reasonably priced ($165~$199 at the time of this review)
o IPS panel
- Cons
o I strained so much to make the monitor show WHITE but I couldnt.
Tried it with warm & cool and with every setting available, it just show yellowish tinted WHITE
o Build quality is really bad, I could see between the frame and the panel,
I end up pressing softly against the panel to find out that it is spongy all over like its made of flimsy plastic
o These monitor are very reflective, I own a MacBook Pro and Ive seen a lot of iMacs around me.
If Ill give a score to the MacBook Pro in reflectiveness it will be: 3.5 out of 5 while S2340M 4.5 out of 5
o Short stand, making the monitor stand lower than anyone would prefer
o No HDMI input
OVERALL: 74 out of 100
## S2440L
- Pros
o Solid build, the glass look rigid with no spongy spots what so ever
o Touch sensitive OSD buttons
o Edge to edge glass
o HDMI input
o A bit responsive than the 2340M, although this is in paper and I couldnt tell the difference or notice it
o The white does look white and the contrast overall seems better, colors are good but not as the 2340Ms
o Reasonably priced ($179~$240 at the time of this review)
- Cons
o The Viewing angles are lower than the ones on the 2340M
o Very reflective, if Ill give a score to the MacBook Pro in reflectiveness it will be: 3.5 out of 5
while S2440L takes 4.5 out of 5
o Glass seems distant from the panel somehow, it gives the feeling of looking inside a box
OVERALL: 86 out of 100
* Note that I lowered the brightness on the monitor and take my phone to watch for any pulse-duration modulation (PDM)
And during my changes I end up with nothing. I cant guarantee that this the case on your panel though
S2340M
S2440L
** Pictures above are in excessive light environment
You could also adjust some settings over your PC that might be helpful for some problems that I encountered!
I just got the S2340M and I also noticed the "spongey" panel! I thought it was just mine and was going to exchange it for another one, but you said you noticed the same thing. Can anyone else that has this monitor verify this? I notice it most on the bottom right corner, it is actually pretty despicable.
Could you please clarify "spongy"? Are you implying the glass looks pitted/discoloured in certain areas or that the panel does?
Mine had some "residue" on it from the foam overwrap which appeared to be caused by the pressure of the styrofoam packing. I cleaned it off with a shammy (chamois cloth) and some distilled water though.
I mean the panel itself squishes in and out when you press on it, particularly in the corners. It is as if the adhesive, or whatever is holding the panel itself down, isn't of high quality. It is pretty absurd. The panel is basically "coming off" if that makes sense. If yours is perfectly sturdy, then I should definitely exchange it.
Yea I would take that back for an exchange/refund. My S2440L isn't like that at all. I can feel "flex" on the back of the casing when I'm pressing down on the glass but, my glass isn't going anywhere. I don't know that I would want to try to use it as a dinner table but, I would say it's fairly sturdy.
Thanks for the reply. Yea, I'm thinking maybe because yours has the edge-to-edge glass is the reason for no flex. Either way, I think I'm going to take it back for a new one. The display itself looks great!
The S2740L is IPS and edge to edge glass though.
And is a fantastic monitor for it's price. The obvious concern with the 27" is the dot pitch, but a 27" 1440p IPS display with a Glossy surface is quite out of my budget since that's a rather specific set of features. The VESA compatibility is really what sold me on the Dell because I use a monitor arm and the only other monitor that matches those features and has VESA, based on my research, are the Apple displays.
I've had a chance to look at all 3 of the current displays since Fry's had the 23" and the 24" on display, as far as build quality goes, the 27" is very sturdy and has a very clean, minimalistic look. I can assume the same goes for the 24" since they share the same design. The stand that comes with the monitor is absolutely terrible though. It was way too flimsy to really support the big 27" screen properly and tended to wobble a bit, it's pretty clear where the cost cutting went, but it isn't a huge con since you have the ability to mount it. The 24" seemed much sturdier on its base.
So I decided to exchange my S2340M for another one and the "give" on the panel around the edges is much less pronounced in this one. But now I am thinking the actual PQ of the first one was superior. Am I just going crazy?? Or is that something that is possible?
It's very possible as there are variances that occur during the manufacturing process of hardware. That holds true for anything being manufactured which is why "tolerances" are used as nothing can ever be exactly the same. What specifically do you think looked better on the original one?
As stated above, it's certainly possible one panel looks better than another. I recall NCX mentioning contrast variances between IPS panels, at the order of something like a 30% difference -- which is sort of an insanely high variation. Maybe they improved that rate with the newest batch of panels, but some may look better than others.
If you exchanged it at a store, I guess you could exchange for another... although you run the risk of getting one even worse.
I had S2340L Rev A00 and S2440L rev A00, so the S2340L had great pctiure quality, vivid colours, but low contrast, i didn't see banding but i had serious flickering/ghosting at games when it went 30 fps, it doubled the image like there was almost two persons like a shilouethe, was anoying and i sent it back and bought the S2440L, the best contrast i've seen, no flicker, no ghosting, the text wasn't pretty sharp like S2340L, colors good but not good as ips, the colors was more washed out and there was obious banding in darker colours, i sent it back because the first sensitive button won't work, so now i don't know wich one to buy back, did someone had this issue?
I'm not entirely sure, but I feel as if the colors aren't as vibrant this time around. Are there any sorts of tests online where I can gauge?
So how do i set the proper gamma and why the text were sharper on ips than amva? That's bug's me and i must admit that i like "vibrant" colours.
The B/G/R thing is interesting and not something I considered. I looked back a couple of posts and saw that the 2440L you got was BGR, not RGB. So I bet a lot of people getting that model has less than optimal text simply because they didn't go back and adjust things in cleartype (nor had even considered it).
I assumed most monitors nowadays was RGB... odd that model is BGR. I wonder if it's the same with most A-MVA models from other manufacturers too -- logically it may be, seeing as the same panels are typically used.
@Racer_J
How did you find the text on it compared to an IPS? The higher contrast should result in better text... at least normally.
Whilst your first comment was not as conspicuous and annoying as some, I'll just remind you that the displays forum recently had to have its' own set of rules and hard line non tolerance of those continually posting stupid ratio/resolution arguments in every thread. May I draw your attention to a similar complaint I made in another thread and Kyle's response:http://hardforum.com/showpost.php?p=1039000744&postcount=43If I see this thread start to descend into the same kind of nonsense as the above thread I won't hesitate to press the report post button. As for your pissy comment about supermarket shopping, I suggest you read the forum rules again. Rule #1 would be a good place to start.
http://hardforum.com/showpost.php?p=1039000802&postcount=44
Also I already pointed out that there are no 27" 1080p IPS monitors, and this is surely the only 27" IPS with a glass screen, whereas 1440p users can choose from Apple, Samsung and a variety of lesser brands and Korean imports.
Finally, as you seem to need to look down on people that are looking for 1080p displays consider that: a) you just sound like a ****, b) people are allowed to have more than one monitor to perform different jobs on different systems.
Welcome to the ignore list. Get off of your high horse.
Now that you are having deep conversation about this... Would you say that Dell S series have similar pictures quality as the Dell U series?
Thanks
I'm not sure as anytime someone says (or writes in this case) "vibrant" the first thing that comes to mind is oversatured, dynamic contrast, and astronomical brightness settings. Nvidia even has a setting called "vibrancy" in their video card control panel (which is actually a saturation slider). I'm not saying that's what your talking about, it's just always the first thing I visualize since a lot of consumers consider that to be "vibrant".
You could look at the Lagom "contrast" test page or the Vanity.dk "colour range" test page since you would be able to see "colour steps" from 0% to 100%. For what oyu're likely wanting to look at, the Vanity.dk page is probably better but you will need to cross reference to the other test pages at Lagom to make sure else looks wrong. In addition to that, you could also use Pasidor page.
If your settings are the same on your replacement monitor as they were on the last one and nothing changed in your video card control panel, you will likely have to change something in order to make the replacement look like the last one. If you don't have calibration hardware though, or have never seen something in person that was properly calibrated, it's going to be a guessing game as to which of the two is "proper" and it could be that neither are. If I were to guess (assuming your last one wasn't calibrated) it likely had a gamma somewhere in the 2.4 to 2.6 range combined with the wrong luminescence from the R/G/B settings which can make colours "bolder" and "pop". I have no idea what you're seeing though nor what you saw.
That is really the crux of the issue though. People see things differently and you can make a display look a lot of different ways that are incorrect yet look how someone wants them too. Case in point, I can make my Dell S2440L have a gamma of around 2.4 (eyeballed with the Lagom "gamma" test page) and I can still see the separation of 2% and 3% black on the Vanity.dk main page. I'm not sure about the separation of 1% and 2% black though as I have some reflections going on right now. There is also a slight bit of black crush in the "viewing cone" but that's expected in that gamma range. My R/G/B is currently in the 40s as I am messing around with ways to reduce the overshoot and the brightness is at 0 for perceived black level depth (as there is usually no ambient lighting). In other words, I have a "dim" image right now but it's "bold" and "rich" at the same time. The gamma isn't staying this low, and was only done and brought up to give you an example.
Since he made that post before you even created your account here I don't think he'll be all that upset about it.
@Racer_J
Thanks for the info. I think the only way I'll ever know for sure if the angles are good enough, is if I eventually try one. But based on what you have said so far, I have a feeling it may be bothersome to me. I expect a 27" VA would be even worse. I wonder if A-MVA would have done better at 16:10, which should narrow down the horizontal issues a bit ... although I guess vertically it'd be worse then. Perhaps baby-sized 21.5" A-MVAs may be best angle-wise.
Thanks for your detailed response. I think the issue involves the bleeding with black backgrounds. First one def have very minimal "fading" in the corners. This one appears to come through more. Call me crazy if that isn't possible to vary from model to model. Colors in general appear great, though.
Only neckbeards care about forum registration dates.
