DDR4 memory selection for z170-based system
heap
Hello, it's been a while since I built my last computer and now I'm researching a new build. This topic is a question about DDR4 memory selection.
So far I have selected the Asus Z170-PRO motherboard and an i7-6700K CPU. I think it's correct (if I'm wrong please let me know) that this bus operates at 2133 Mhz, but depending on the parts you pick it has the potential to be overclocked to higher speeds.
In the past, I've always used the compatibility tool at the crucial.com website and when I do this it gives me Crucial Ballistix Sport DDR4-2400 16-16-16. I'll be getting 32GB (16x2) by the way.
So, is that considered any good? My budget for system memory is no more than $250 and my primary use will be for gaming.
Looking on newegg.com I see some memory that have better specs but I'm unsure about compatibility. For example, the G.SKILL TridentZ DDR4 3200 14-14-14-34.
One thing I'm really concerned with is memory stability and I'm not sure how aggressive 3200 Mhz is and whether I should go down to 3000 Mhz or even 2800 Mhz. For example, G.SKILL TridentZ DDR 2800 with 14-14-14-35 timings.
Thanks!
2800 - 3000 seems to be the sweet spot with Skylake.
You should be able to get 32gb of DDR4 3000 for $170 or less.
G. Skill is a good brand. That 14-14-14-34 set is a great deal. They also have a 15-15-15 DDR 2800 set, for a bit less money. G.Skill has pretty high compatibility. However, you could email them, to be sure. They will respond.
*I just put some "TeamGroup" DDR4 into a Gigabyte board and it is working great. Good value.
