Flogger23m
- Jun 19, 2009
Looks like FC3 is no longer on Steam. Not sure why.
You can buy the planes individually but the price will be higher. I believe that is because they planned on having Flaming Cliffs 2024 out but the update got delayed and I assume putting up the old listing page on Steam takes some effort. If you buy from their own store you can get it for $25 still, and you'll get $2.50 in store credit. You can put that towards the FC 2024 upgrade which would be $7.50. Most DCS store products have "MIles", and 1000 Miles = $1 in store credit. You get around 25,000 Miles for FC3.
For the cheap HOTAS... I heard good things about them for entry level controllers but if you plan on using it long term you may want to spend more. My $130 X52Pro has lasted over a decade though some of the buttons are getting loose. I think they charge $200 for it now. These days I think VKB and some other brand that is not Thrustmaster (cannot recall the brand) are the preferred choices.
I recently bought the JF-17 and F-14, and that gives me enough Miles to get FC 2024 for free I believe.
