MisterDNA
- Feb 8, 2004
Sun goes behind the Wellsville Mountains at 4:30, sets at 5PM and we're in darkness at 5:30 this time of year with DST to blame. This calls for a little help:
That should do it.
I put the conduit together temporarily as a jig. Good thing because I was off a bit and had to square the sides.
The shovel is in place to show the final grade after backfill and gravel. 24" from the bottom of the shovel handle to the top of the pipe. That's six inches more than I need, but that's because I need sand under the pipes. Sand is used for several reasons:
1. Serves as a potential warning to backhoe operators.
2. No rocks to damage the pipe (or direct-burial cable).
3. Doesn't self-compact as much over time as standard soil does so your pipe stays straight over the, hopefully, many years it's in service.
I will have to cut the soil back at the elbow to allow for the sand since I want to keep the data lines as far from the power line as possible.
That should do it.
