dondan
- Apr 15, 2013
If you view the video you can see that the metal sheet + 3M tape + tempered glass sandwitch is very thick. You need 6.5mm for it. Take a look on your ruler and you will see how thick this is. On a 40L case this doesn't matter but on the C4-SFX the case will bee much wider 127.3mm vs 137.5mm.
Maybe it will be possible if Lian Li could get 4mm tempered glass from china and i will glue the glass from the inside on the panel like the new panels for the M1.
