When the Kickstarter goes up again, are there any changes to the case for the "v2"?
I'm running a 1080ti with a 4790k at stock with a 450w. No issues so far but I am sure its probably shortening the lifespan of the PSU pushing it that hard.With the FTW3, are we running the limits on sf600w?
I was getting worried because the FTW3 consumes 20w more, and I already maxed hard drive capacity and LEDs.I'm running a 1080ti with a 4790k at stock with a 450w. No issues so far but I am sure its probably shortening the lifespan of the PSU pushing it that hard.
For Top tier gpu builds, at least 500w for longevity to me and that is without overclocking or overclocking perhaps the cpu to near stock voltage at base speeds. Unfortunately since there are no quality 500-550w SFX units (Enermax is just okay), we are stuck with SF600. I am not quite a fan of 600w SFX psus since to have that much power in a small package needs pretty good cooling, so I do not know how long that unit will last in a real world case. I really want a Superflower-based SFX psu or a psu with near the performance of the Corsair SF series but with better/more flexible stock cables.I was getting worried because the FTW3 consumes 20w more, and I already maxed hard drive capacity and LEDs.
Yeah same here. would be nice to see eVGA come out with an SFX psu as their psus as of late have been quality.FSP's new SFX PSUs look pretty promising, though it's a shame they only have an 80mm fan. Just waiting on Jonnyguru to publish a review.
1. Rubber feets instead of metal feets for better grip with the same look
2. 92mm case fan mount point if you not use the hdd bay ( will also support Asetek 92mm AIO)
3. A cover plate for the GPU mounting hole
4. Better centered USB front port
5. Stamp-in motherboard stand-off instead of screwed ones
Thanks for the confirmation, ordered mine once I seen your post... will be here this weekThe FTW3 fits.
You have to unscrew the PCI slot and fold it out of the way and get the card in first, then push the PCI slot onto the card and screw it back in.
Sorry for the crappy photo, will take some better ones later if requested.
I use these for the Noctua fan:How are you guys obtaining the fan clips for the Noctua fan and LP53?
I purchased a Noctua Fan / NH-L9i kit to use the Fan and clips on the LP53. However, the fan is screwed into the heatsink and not attached with the needed clips.
Note that the Astek will give owners of the Strix board issues due to the location of the ram. (Side where the hoses will cross over)
If you look at Dan's X99 board, the ram is located at the bottom of the board.
I personally had issues because the hoses were not long enough to make the loop across the bottom of the ram and back to the socket.
Will break it out and try once again this weekend. (with photos)
That would be a new case entirely, i dont think that is gna happen with his focus on that heatsink.Dan, have you given any thought to ventilating the top of the A4 and leaving mounting points and grommets so those that are willing to make the case a little taller can mount 240 rads (maybe call it the B4)?
Those looking for power supplies, enermax recently released two new SFX PSUs, a 550W and a 650W, see for instance here:
https://smallformfactor.net/reviews/powersupplies/enermax-revolution-sfx-550w-review
Don't know if they are any good (they probably are), just a new player in the SFX market to add to the list.
We need some reputable PSU makers entering the SFX market under their own banner. Seasonic, Super Flower etc.They are decent, but Corsair SF series is just better than it in pretty much every regard while being maybe $10 or so more expensive. We need eVGA to enter in the SFX psu market.
I used to like Seasonic, but it seems that they can be pretty hit or miss. A friend of mine had the old Seasonic Platinum psu and it died on him in just a month. Super Flower is the king of PSUs now imo, but Seasonic-based psus should fare just fine.We need some reputable PSU makers entering the SFX market under their own banner. Seasonic, Super Flower etc.
I mentioned eVGA just because they use SuperFlower for their most recent psus.Finally someone mentioning the important ones. Absolutely love Seasonic stuff. I hope they will enter the SFX asap.
That's the main reason I subscribed to the channel. They have given SFF cases the promotion they deserve.As much as I am not a fan of Linus, I am glad that he is giving good exposure to mini-itx especially the custom mini-itx cases like Dan A4, Sentry, and Ncase M1.
UK delivery only and only one left:
https://www.amazon.co.uk/gp/aw/d/B0..._SY340_FMwebp_QL65&keywords=ryzen+itx+biostsr
Edit: wow price went up, I got it for 119...
It has USB C, but not Thunderbolt 3, like:
Here my setup:
Strix z270i
2x8gb 3200 cl16 rgb ram (g.skill)
1x 960evo
Silverstone sfx-l 500W
i7 7700k delided & relidded.
Noctua lh9i stock.
My max temps hover around 87 C under load (cinebench)
And my cinebench score is around 915-1028 which is kinda funny because it is overclocked onto 4.8Ghz vcore 1.28...
Anyone experiencing those kinda flexible results with the i7?
Aida 64 reports 100% constant usage on 4.8 under prime95. Once i clocked it down to 4.4Ghz the new cinebench result is 876, which is worse than stock... i don`t know but after my delid it seems that all specs went down except the put in overclocks. For what the clock is, the benchmarks are not as good as stock... at least temps are nicesome cores must be shutting down because of the overclock. run a stress test on prime 95 with these settings https://i.imgur.com/UhzFIPz.jpg and check on aida64 in the stress test monitoring window (without running the aida64 stress test) if you're keeping 100% activity . try running at 4.4ghz and you should get a higher score if it really was some cores shutting down during the cinebench benchmark.
