And a next try
I like the upper version very much its the eva font of you last link SaperPL.
But the lines of the upper version are very thin so i think it is very difficult to make a sticker out of it. So it must be an engraving and you cant remove it.
And a next try
How about providing the logo as a sticker like intel ?
So people could stick this to any place they want. I personally don't like the logo in the front panel.
And a next try
I don't get one thing - why do you keep putting this A4 on the logo guys?
The product name shouldn't be a part of brand/company name logo. Those are two separate things. Compiling those together makes situation where each product has different brand logo.
The product name A4 isn't something really marketable, so I'd keep that just on a name plate on the back or somewhere inside.
Make a proper "DAN" brand logo separately first - you don't have loads of product lines to make distinct logos for them. Promote it somehow on the case front.
Also don't put multiple coloured letters in logo. Apart from industry standard front panel colours such as USB3.0 blue and optional audio green and pink try to keep everything black and white or greyscale. This will retain the classy look fitting everywhere.
And a next try
Sorry i dont get it can you please show me what you mean at a picture?
What do you think of this? I know total different as the others but i like it.
Here is the font: http://www.dafont.com/milenio-jed.font?text=DAN&fpp=100&psize=l&l
First one is best. Sticker please. Not milling.And a next try
Hello all
I recently just discovered the NCase M1 as I was looking var the smallest case possible to fit my current system. I have the Bitfenix Prodigy, which is one of the largest m-itx cases out there. In my opnion the whole idea of a m-itx system is to build a small gaming rig with enough cooling to keep the whole thing running smooth under load. The only problem with the NCase is that is doesn't fit a full size GPU
I then discovered the A4 and it really caught my attention. It's about as small as it gets without suffering from effecient cooling. Well done with the work so far!!!
The only thing bothering we is maybe the case front. It's clean and and timeless - yes, but personally I miss some kind of unique feature, which kind of states the unique quality of the case. Where as the NCase have the cutout in the bottom, which makes it look very slick. Maybe you could do some kind of bulge or inverted bulge (if that's even a frase) if you know what i mean. The case looks awesome, but is missing a unique element to make it stand out.
Don't know if I'm too late with this suggestion, but gave it a go anyway
Sweet jeebus NO. Adding extraneous "bulges" is pretty much the stereotype of awful PC case design, one of the main points of cases like these is to do away with that nonsense.Hello all
It "stands out" by exactly not having such unnecessary clutter that the vast majority of poorly designed PC cases have. The entire point of this is minimalism, to add the same type of gaudy clutter that 99% of PC cases have would defeat the purpose.The case looks awesome, but is missing a unique element to make it stand out.
I mean really, do you think Apple's designs are lauded despite their lack of "bulges"?
What the hell is that thing? The "Ultim4te G4mer M4chine eXtreme Fatal1ty PWNZ edition"?
Hah, Deepcool FTL! The Steam Castle, also available in camo, why I do not know.
Not entirely sure what you mean about full size GPU's in the Ncase, plenty of 980's and titans in them, unless you mean dual GPU cards like the 295x2.
I have an Asus R9-280X and the height of this card will not fit in the NCase M1 simply because the large heatpipes on the top of the card. It's too wide to get the sidepanel closed.
Please correct me if I'm wrong, but quite sure I got the measurements correct
The second option. Right corner!
