I'd post gameplay pictures, but there isn't any, so here are my specs. Make your mind up from the bajillions of screenshots you've all already seen, and then go and do something worthwhile.
Yeah, I guess so. I'm taking screenshots using the editor, so I think it should be understood that I can load any level and go anywhere to take images. But by now, every review, article and video card review mentionned that there's an alien ship and a carrier battle so I don't think there's much left to spoil in terms of what levels to expect.Someone needs to put "Spoilers" in the title or at least at the beginning of the thread.
1680x1050 4aa with vsync
xfx 8800gts g92 with rivatuner 780/1950/1050 stock cooling but fans are controlled by riva based on heat
p5b-e q6600 g0 @3.3 stock vcore 2gb memory 1:1 @367 4-4-4-10 onboard sound
xp pro 32
config
natural mod 2.02
ragdoll and blood effects for crysis 1.1
Realtime Water Physics mod
skins for both the socom and scar
tweaked autoexec and CVarGroups from somebody named 'Hélder [HP] Pinto"
first level is physisIII the other is Country Path
*snip*
Thanks! What frames are you getting? Can you link me to the tweaked config?
*snip*
i use this config however by default it has vsync and TripleBuffering disabled and some other tweaked values i've changed to my preference so be sure to open it up and customize to your liking
how do i display the framerate when taking screenshots is that what show developer info does
you should only enable TripleBuffering if using vsync
Tripple buffering uses more video memory (since there's an extra back buffer that needs to be created)
it is (generally) used when enabling VSync, the 3rd back buffer means that you will always have a free back buffer to render into and there will always be a back buffer available to flip with the front buffer on verticle refresh. This allows the graphics hardware to avoid stalling while waiting for the monitor to refresh. If you aren't enabling VSync then there really isn't a good reason for enabling tripple buffering
no tweaks for performance but if you want better frames just disable aa
here is my autoexec
you could just make backups for when you mp that way you can have your cake and eat it too
