Denpepe
- Oct 26, 2015
Several years ago they did. Employees not being paid, studios closing, games getting canceled. I haven't heard anything about it recently. Sounds like they restructured pretty heavily and are working on a rebound. It would make sense that they're still playing it safe though. This release, after all, is safe. I'm sure the cost of significantly less than developing a new AAA release, and should do well on consoles (I expect particularly good results on Switch since that seems to be a platform people are more likely to double dip on). It's an easy way to get a quick cash infusion and move onto something more ambitious. To that end, I absolutely agree... making a deal with EGS is smart. People don't have to like it, but it's a smart business move for a company that needs to be making smart business moves.
As I already addressed, this isn't likely to be a huge seller on PC anyway...
This actually doesn't look to bad. Framerate looked questionable though. If it consistently looks like that, and I can get it to run at 4K 60fps... i'd probably revisit it.
Looks pretty friggin awesome to me. And yep, looks a lot like Hunt Showdown.That would be https://www.huntshowdown.com/
Hunt Showdown runs my 6 core 8600K at 5GHz+ at 85%+. With a 2080Ti at 2GHz+ and almost everything turned on graphically it will run about 120FPS at 1440p.Although I'm sure they will mostly focus on the graphical upgrades, I'm mostly looking forward to the performance enhancements on the newer engine since the original game is pretty much bottlenecked by only using 1-2 threads and is highely reliant on clock speed for performance. I just played the whole series for the first time earlier this year and both my CPU/GPU utilization was at like 30% while playing the game and frame rate varied wildly between 30-100+ FPS for me on a 2700X/2080 setup. Plus it was pretty unstable for me, crashing every so often despite downloading the 64-bit GoG files for my Steam version. The only thing that fixed the instability for me was lowering a couple of the IQ settings (can't remember which now..) or maybe running in DX 10 or 9 mode, whichever lowest one it supported.
Crysis Remastered system requirements
The remaster boasts better textures, improved assets, SSDO, SVOGI, "state-of-the-art depth fields," particles effects and more...Crysis Remastered releases September 19th...
minimum system requirements
OS: Windows 10 64-bit
Processor: Intel Core i5-3450 / AMD Ryzen 3
Memory: 8GB
Storage: 20GB
Direct X: DX11
GPU: Nvidia GeForce GTX 1050 Ti / AMD Radeon 470
GPU memory: 4GB in 1080p
recommended system requirements
Processor: Intel Core i5-7600k or higher / AMD Ryzen 5 or higher
Memory: 12GB
Storage: 20GB
Direct X: DX11
GPU: Nvidia GeForce GTX 1660 Ti / AMD Radeon Vega 56
GPU memory: 8GB in 1080p
I gots a 2080super and wonder if this will max out a 1440p ultrawide
Huh, ray tracing even on 8th-gen consoles: https://www.eurogamer.net/articles/...stered-your-first-look-at-console-ray-tracing
Same card and res here, so hoping for 50+ FPS with G-sync. If not, I may wait until I can acquire a 3080 to play through this. If only it had DLSS support.
Yeah, Digital Foundry did a video yesterday showing ray tracing on Xbone X:
Pretty cool, despite it being restricted to 1080p/30 with RT enabled and not everything is ray traced. It's amazing current consoles can do it at all and bodes well for next gen consoles.
Crysis Remastered- Ray Tracing
why don't more games use software ray tracing?
Ray Tracing is a no go .. maybe 25 fps .. So I decided to go 1080p Low and use Radeon Image Sharpener and it looks good like that to me .
Project Lead of Crysis Remastered, Steffen Halbig: "In 4k, there is no card out there which can run it in 'Can it Run Crysis mode' at 30 FPS"
https://www.pcgamer.com/crysis-remastered-can-it-run-crysis/
Yep. I loved the original but this seems more like a low-effort cash grab than a labor of love.According to this, Crysis Remastered still suffers from the same single core issues of the original. If this is true it's very disappointing.
https://www.dsogaming.com/pc-perfor...eaded-cpu-issues-just-like-the-original-game/
