Where did you do that? Even when I snipe with a silenced gun the AI would start to band together to and start searching for me.
If I sniped far enough away (50+ yards ~ maybe?) the AI would be alerted, if I missed, but not looking for me specifically. Usually if I miss, the alert bar goes up, hit the second shot, and it goes away because only that soldier became aware.
- Also, I want to know if anyone thinks my CPU is bottlenecking in crysis? I was playing around with the settings seeing what resolution I could play with max settings and to see how high of a framerate I could get in each res/setting combo. When I got down to 800x600 (lowest res) with all settings at LOW, indoors (this is all according to FRAPS) my avg fps is 50, and outdoors, I'm lucky if it stays above 30? I get the same framerate at 1680x1050 with all settings on low (the settings i normally play on). I have a 7950gt at 630/715 and an x2 5000+ @ 3.2ghz. I didn't think an x2 at these speeds wouldn't be able to handle crysis at 800x600? What fps do you C2D guys get at 800x600 with low settings (if anyone minds checking for me)?
