I just built a new rig:
Case Corsair Carbide Series 500R
PSU Cooler Master Silent Pro 700W
CPU Intel i7-3770K
Mobo ASRock Z77 Extreme 4
Cooler Cooler Master Hyper 212 Evo
RAM Crucial Ballistix Tactical 8GB x4
SSD Samsung 840 Pro 256G
And here are the baseline temps...
Prime95 for 1hr (Max Temp 63c):
IntelBurnTest (Max Temp 68c):
I am nervous about these results, because my previous OC (5yrs ago), I was able to take a Stock Q6600 (2.4Ghz) under-load with a Max temp of 48c, to 3.6Ghz with a Max temp of 56c...
And now I am already reaching 68c w/out OCing, what happened to CPUs in the past 5yrs that caused these temps to start out so high?
Granted I lapped my previous CPU cooler (Ultra-120 Extreme w/ Scythe S-FLEX SFF21F), maybe that is the trick, is the CM Hyper 212 Evo just not cut out for keeping this CPU running cool, or do I need to LAP it, or have CPU's changed that makes them not OC friendly or run hotter?
Thank you for your time,
-BassKozz
CPU Intel i7-3770K
-BassKozz
