Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
This is one those things I feel like I keep learning and forgetting. So quick question….for a gaming only computer, is there any reason to get anything faster than say a i5-12400 if I’m gaming at 4K?
Well I wanted to get something now and found a 12400 for $150 so just went that route and I’ll upgrade later if needed. GPU is a 3080 btw and I plan to play some older games like portal 2 and halo mcc.
Yeah, at 4K, unless you are lowering your settings at 4K or chasing benchmarks, you are almost always going to be 100% GPU limited. As long as your CPU is within a generation or 2, you will be fine.
A bit like for 1080, depend what your aimed FPS, video card and game you play on a 3080 should be ok (and ok would englobe a very large amount of CPU a 9900k certainly would be OK and is a good step below a 12400).
There is reasons to get a better cpu, has it tend to affect everything the computer do and in some game situation the 1% low and even average FPS would be higher, is it worth it to you, being quite subjective.
Someone tested 2600x to 7600x (2600-3600-5600) with a 1080TI with a 2600x has a reference has well, cpu usage and FPS in games at 1440p and 4k:
For some game at 4K the average does not move but 1% low get a near 50% jump (like at 8:37)
Would be nice to have it for more regular next gen GPU has well, were the notion on being on a budget or still on a 2600-3600 would be more common among buyers
