- May 4, 2006
I came home to my PC being off and It never happens it's a 24/7 on a massive battery backup that even an hour long power outage won't shut it off.
I turn it on and very quickly it slowed down and saw the cpu at low clock speed before shutting off. I knew what happened.
With that said, I don't know what I want to get. I didn't really like this cooler with my 5930k at 4.5Ghz (1.270v) as it got very hot reaching 85C when maxed out for a few minutes. So far my options seem to be a Corsair H150i PRO or going with a custom loop again but after pricing it out it will be a little over $400 for some quality stuff.
Then I saw these:
Alphacool Eissturm Hurricane Copper 45 3x120mm -Complete Kit
http://www.performance-pcs.com/alphacool-eissturm-hurricane-copper-45-3x120mm-complete-kit.html
EK-KIT P360 Premium Watercooler Kit - R1.3
https://www.performance-pcs.com/ek-kit-p360-premium-watercooler-kit.html
What are the thoughts on those two complete kits? I know the EK kit is a good quality kit but are these advisable? Or is it a waste and I should go with another AIO?
My case is a Corsair 750D and 45mm thick radiator would the max I would go due to space limitations
Then I saw these:
